Multiphase Flow with Chorin's Projection Method
Old   August 16, 2002, 07:09
Default Multiphase Flow with Chorin's Projection Method
Stefan Leschka
Hello Sir or Madam:
I am trying to model multiphase flow in a bubble column reactor. The basis of my program has been a single phase model using the projection method by Chorin. I know, most researchers use the SIMPLE or SIMPLER algorithm for multiphase problems, which allow larger time steps. However, does anyone of you have some experience unsing the proyection method? I am interested in advantages/dsadvantages of this method.
Thanks in advance, Stefan Leschka
Old   August 16, 2002, 14:46
Default Re: Multiphase Flow with Chorin's Projection Metho
Tony
It is not the problem with time steps. Chorin¡¯s classic projection scheme is only first-order and subject to a spurious boundary layer when the viscosity is relatively large. However, in multiphase flows, any claimed second-order scheme will degenerates to first-order unless one treats the pressure discontinuous across the interface and without using regularization of singularities. To my knowledge, there is only one second-order method so far in the finite difference context, which is done by Li and Lai (J. Comput. Phys. 171, 822-842, 2001). It could be done much easier in the finite element of volume context, since the singularities are integratable.
Hope this helps.
Old   August 20, 2002, 15:46
Stefan Leschka
Thank you very much. I changed my algorithm and now it should be something like the SIMPLE algorithm.
Regards, Stefan
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
SIMPLE method for inviscid flow abcdef123 Main CFD Forum 0 February 26, 2010 08:24
Solid-liquid flow (Eulerian-Eulerian multiphase model). panzer CFX 0 February 23, 2010 23:27
Multiphase flow for flow around ship gundul CFX 5 September 2, 2008 16:06
free surface flow and projection methods sylvain Main CFD Forum 2 April 26, 2002 09:45
