Heat Transfer Benchmarking
Old   February 5, 1999, 05:24
Default Heat Transfer Benchmarking
Joakim Brink
I am using FLUENT/UNS for CFD-calculations in the area of electronic cooling equipment and climate control in vehicles.
I would like to validate this code for this type of fluid flow, therefore I am looking for good benchmark cases with experimentell results available or in second hand a well dokumented analytical solution.
If requested I am willing to pay for copies of extensive and well dokumented reports.
telephone: +46 586 81287 faximile: +46 586 85882
Old   February 8, 1999, 13:33
Default Re: Heat Transfer Benchmarking
John C. Chien
Based on my previous experience, uniform tri/ or hybird quad/ mesh on the wall is essential for consistent wall heat transfer calculation. Non-uniform tri/ mesh on the wall will give you non-consistent results, unless all the wall mesh sizes are very small and inside the linear sublayer region. (assuming that the low Re two-layer model is used)
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
