Onera M6 wing
Old   November 7, 2002, 00:18
Default Onera M6 wing
sheetal
Dear All,
Has anybody solved the Onera M6 wing problem mentioned on site
http://www.grc.nasa.gov/WWW/wind/val...ng/m6wing.html
I have solved this in CFX Tascflow but the results are not matching with the experimental data given on the site. Please share your experiences.
regards, sheetal
Old   November 7, 2002, 06:32
Default Re: Onera M6 wing
Li Yang
The exerimental data should be correct. You can check the data in the original report: AGARD-AR-138.
Regards
Li
Old   November 7, 2002, 07:47
Praveen
This is a very gentlemanly problem which every beginner of aerospace cfd solves. Mybe you should give details of your grid and flow solver, and tell us how the results differ from experiments ?
Old   November 8, 2002, 07:05
sheetal
Hi!
The grid size is approx. 0.75 million. I solved the problem using k-w as well as k-e model (CFX TASCflow). I tried UD as well as modified linear profile schemes. But all the results are more or less same. The exp data shows that there is shock formation at approx middle of the suction side of the wing. But my analysis shows that the shock is blown off from the surface. Means the results are like analysis done for lower angle of incidence or higher Mach number with respect to the experiment. The pressure coefficients plots are not matching especially on suction (top) side.
I am going through AGARD. Thanks
Sheetal
Old   November 10, 2002, 12:34
boling
How about your grid distribution in the direction normal to the wall? Accoring to my experience, if there were not enough grids in boundary layer , you could not get the correct solution if you are using k-w model.
Old   November 11, 2002, 00:15
Sheetal
I have already checked the grid distribution near the boundary. It is ok. I used structured mesh generated in ICEM Hexa. Has anybody solved the problem and got the correct result? The experimental results should be correct. Code may not be simulating correctly. On the same site they have mentioned the simulation done with WIND code and got the matching results.
Thanks,
Sheetal
Old   November 11, 2002, 12:01
boling
could you try to solve the problem using the grid from that webpage ? I used to solve that using the grid from the webpage, it worked well.
Old   November 11, 2002, 23:52
sheetal
Thanks boling!
I will do that.
Sheetal
Old   November 12, 2002, 14:33
Neale
What do you mean by the grid distribution is OK at the boundary. How many control volumes do you have in the boundary layer?
You should probably be using SST with the automatic wall funciton treatment for this case, rather than k-omega or k-epsilon. Make sure you have at least 5-6 control volumes in your boundary layer with SST.
Neale.
Old   May 28, 2009, 11:30
Subramanya Naik
Subramanya_Naik is on a distinguished road
Hi. Can anybody please forward me experimental data for Onera M6 wing. I am new to this . Can you help me? my mail id is ansubramanya@gmail.com
Subramanya_Naik is offline   Reply With Quote
Onera M6 Wing Mesh salvoblack OpenFOAM 10 January 23, 2021 11:52
M6 ONERA Wing profile Cyril A. Main CFD Forum 18 December 31, 2016 14:59
Set ONERA M6 Wing Initial Condition Dianhong Main CFD Forum 1 January 20, 2016 05:19
Trouble when using MUSCL scheme on ONERA M6 wing Aurélien FLUENT 2 January 23, 2013 07:42
Onera Wing Wall function? Dianhong Main CFD Forum 0 November 21, 2003 20:19
