negative pressure
Old   November 22, 2002, 10:01
Default negative pressure
manjgi
This is a general fluid mechanics question: Suppose that we have a venturi conduit (entry segment of radius R1 reducing linearly to R2; middle segment of steady radius R2; exit segment of radius R2 and increasing linearly to R1) . Say now that we have an incompressible flow throughout the conduit and the flow exits the conduit at an ambient pressure say p0. Is it possible to reduce the diameter of the middle segment (R1) in such a scale so at some point in the middle segment the pressure would be less than p0 or even negative?
This is something I came accross while simulating a venturi flow and taking dimensionless p0=1. It would give me negative pressure in the middle segment. Would that have any sense?
thanks for your time
Old   November 22, 2002, 11:09
Default Re: negative pressure
xueying
Pressure is a relative value in fluid mechanics, so there's no problem with negative pressure. In your case, it makes sense.
Old   November 22, 2002, 11:25
Praveen
For incompressible flow, pressure is defined only upto a constant. This is because pressure only appears as a gradient in the fluid equations for incompressible flow. You talk of pressure differences only so that the constant does not matter. Of course in reality you must look out for cavitation.
Old   November 23, 2002, 18:05
Thinker
one way to simplify this is to take a condition such that value of pressure at any one node is taken as zero and the other values are all relative to it and u can take a contour plot of the same to see ur output
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
seeking for help about a room with negative pressure mengyue1 FLUENT 0 November 26, 2009 06:40
High pressure in rhopSonicFoam results in negative pressure shangzung OpenFOAM 0 November 5, 2009 03:24
negative pressure in cfx flar.t CFX 1 December 18, 2006 23:20
negative pressure mAx FLUENT 0 January 25, 2006 14:31
