Transforming results in rotating reference frame
Old   November 27, 2002, 04:50
Default Transforming results in rotating reference frame
Mark Render
Hi all,
I've calculated a mixer flow with rotating frame of reference. In post processing get the variables in the stationary coordinate system. If I want to have the results seen from the rotating impeller I decided to subtract the circumferancial velocity from my results. And now I'm thinking if I have to manipulate the pressure also ?
Could someone give some thought about that ?
Regards,
Mark
Old   November 27, 2002, 07:20
Default Re: Transforming results in rotating reference fra
Praveen
By pressure I assume you are refering to STATIC pressure. This does not depend on the motion of the reference frame, because pressure at a point is the normal force per unit area exerted on an imaginary surface that is moving at the local fluid velocity. This pressure is isotropic so that orientation of the surface is not important.
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
Multiphase in rotating reference frame M_W FLUENT 0 March 18, 2009 10:24
Rotating Reference Frame Ketan FLUENT 0 May 17, 2007 13:13
rotating reference frame Pei-Ying Hsieh Main CFD Forum 1 April 5, 2006 08:54
about mutiple rotating reference frame lingo FLUENT 0 December 12, 2002 04:13
