Meshing Error !!!
Old   January 3, 2003, 12:42
Default Meshing Error !!!
bharath
hello
I got an Error saying "Non positive Volumes Exist, Grid Check Failed " while doing a grid Check in Fluent. why is this happening ?? and wht should i do to get the error out ?
Thanks
Bharath
Old   January 4, 2003, 11:47
Default Re: Meshing Error !!!
Marc
Check the volume of the cells in the tool, where you created them. Probably you have some bad quality cells somewhere. Hex or tet mesh? Any edges defined with zero lenght?
Marc
Old   January 4, 2003, 17:24
Try the Fluent forum.
Yes, the connectivity of the mesh might be poor. Also, if you check the max and min cell sizes, you will see where the negative sizes are. I have not used Fluent for over a year, but I think remeshing is the most likely solution. Try the Fluent forum....more helpful.
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
