About the POD
Like Tree1Likes
  • 1 Post By Peter Attar
Old   February 19, 2003, 11:29
Default About the POD
wudor
It is said that one can reduce the time and cost of computation by use of reduced-order models. While when we reconstruct the flow field, the initial data from the numerical simulation or experiments are still needed. It seems that it doesn't reduce the data storage. Thanks.
Old   February 19, 2003, 16:32
Default Re: About the POD
Peter Attar
I'm not quite sure what you mean by data storage. While it is true that to construct a POD reduced order model simulation data from the original full model must be computed at least once, from then on the reduced system is much smaller and computation can be made much faster..
Old   February 20, 2003, 11:14
wudor
I am sorry I don't know much about the POD, but what kind of computation can be made much faster?
Old   February 20, 2003, 11:23
Peter Attar
The speed of computation is more or less based on the number of DOF to be solved for. POD reduces this number...therefore the computation is sped up. It has been applied to aerodynamic and aeroelastic computations which used vortex lattice,Euler and Navier Stokes fluid equations. Look for the authors Dowell,Hall and Thomas for references.
Old   February 20, 2003, 11:54
Question Man.
Ignoreance is bliss!!, but what is POD? Can someone explain it?
Old   February 20, 2003, 12:23
Tim
check out:
G Berkooz, P Holmes, and JL Lumley. "The Proper Orthogonal Decomposition in the Analysis of Turbulent Flows", Annu. Rev. Fluid Mech. 1993 , Vol. 25: 539-575.
Old   February 20, 2003, 12:25
Peter Attar
Proper Orthogonal Decomposition. Essentially it is a coordinate transformation which maps the flow variables(for example pressure,velocity,density) from a large dimension subspace to a smaller dimension subspace via the coordinate transform. It is of the same thought as what is done with structural dynamics where the structural deformation can be thought of as a linear combination of some global modes...for the fluid simulation the pressure etc can be described by a reduced set of bases. The bases("modes") are found by solving the eigenvalue problem [C]{v}=lamda{v} where C is the correlation matrix formed by putting snapshots of the original full model data into a matrix(call it Q) a forming the correlation C=Q*Q^T. The POD modes are then formed via [U]=[Q][V] See the reference I gave above for more(better) detail.
randolph likes this.
Pod nikwin OpenFOAM 3 April 9, 2010 07:12
POD or ROM (Proper Orthogonal Decomposition) mike Main CFD Forum 8 June 10, 2006 03:39
Snapshot Proper Orthogonal Decomposition (POD) Mehmet SEN Main CFD Forum 7 May 19, 2006 12:38
What is the difference between POD and SVD? Greene Main CFD Forum 1 February 15, 2006 17:32
Looking for free POD program for Euler equations TooT Main CFD Forum 0 August 15, 2003 21:31
