Compressible 2 phase flow package?
Old   March 10, 2003, 11:29
Default Compressible 2 phase flow package?
Matej
Is there any code, that can cope with two phase flow with at least on phase compressible?
My case is simply ejection of fluid from confined vessel caused by sudden evaporation. Can STAR_CD or FLUENT do it? CXF cannot.
thanks,
Matej
Old   March 11, 2003, 05:59
Default Re: Compressible 2 phase flow package?
aid
Do you know the mathematical structure of your compressible 2 phase flow?
Old   March 11, 2003, 07:52
Matej
You mean probably the set of equations I need to solve, if I get it right?
Yes.I gues I have the idea what to solve, but I do not have a time to write my own code, I need something which i can use ).
matej
Old   March 11, 2003, 08:17
Joern Beilke
http://www.nabla.co.uk
... and it is free for academic use.
Old   March 11, 2003, 08:31
Jens
Hi
You should be able to do in Star-cd.
I am working with the beta version of the new v3.2.
It got a feature called compressible VOF method, which also can handle condensation etc.
Kind Regards
Jens
low speed compressible flow lily CFX 2 November 16, 2005 05:15
Multiphase flow problem icedou FLUENT 6 July 10, 2005 02:52
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
