LES in Turbulence
Old   May 30, 2003, 03:43
Default LES in Turbulence
K.K.J.Ranga Dinesh
Hi Friends
These days I'm studing the Large Eddy simulations for Turbulence. Why we want to introduce the filtered velocity for LES? and why we filtered Navier-Stokes equation for the LES?
Thank you
Ranga
Old   May 30, 2003, 06:13
Default Re: LES in Turbulence
Manosh
In LES, you must need to use a filter (there are some different types of filters in literature) to seperate large eddies which you will simulate directly from the small eddies which you will model.
Just think a filter is like a net, using this you will catch big fishes (wavenumber < cut off wavenumber) and drop small fishes (wavenumber > cut off wavenumber).
Hope this helps.
Manosh
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Naive question about turbulence and LES Renato Main CFD Forum 1 October 4, 2005 23:01
