time steps in transient heat transfer in solids
Old   June 5, 2003, 04:04
Default time steps in transient heat transfer in solids
Mike
Is there any criteria for the time steps doing transient calculation with heat transfer in solids?
I found one for the convective mass transport saying
2*dt*nu/rho < L^2
L ... mean mesh size dt ... time step rho ... density nu ... dynamic viscosity
Is that criteria correct?
Is it possible to compare the energy-equation with the one for mass transport, so that I get a similar criteria for heat transport in solids?:
2*dt*lambda/(rho*cp) < L^2
L ... mean mesh size dt ... time step rho ... desnity lambda ... heat conduct. of solid cp ... spec. heat
Thanks in advance for every answer Mike
Old   June 5, 2003, 04:58
Default Re: time steps in transient heat transfer in solid
gorka
It depends on whether you use an explicit or implicit method for time discretization. Usually:
Explicit: 2*dt*lambda/(rho*cp) < L^2 (as you have pointed out)
Implicit: No restrictions for convergence (only for accuracy)
Semi-implicit (Crank-Nicolson): No retrictions for convergence but a restriction to avoid unphysical results:
Hope this helps,
Gorka
Old   June 5, 2003, 05:30
Mike
Thank you very much - that really helps a lot, Gorka.
I have an implicit scheme, so it should be only a question of accuracy.
Do you have any advice how I can measure or see accuracy without having experimental data? Or is there any hint how to choose the time steps in fully imclicit scheme?
Mike
Old   June 5, 2003, 05:47
gorka
The Implicit scheme is first order accurate unless you use results from the two previous time-steps (n and n-1, being n+1 the new time step, in which you evaluate the terms). Therefore, you should use small time steps if you want to obtain accurate results. Sorry but I donīt know any specific criterium.
Gorka
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Transient Conjugate Heat Transfer Raja FLUENT 2 September 30, 2008 01:59
transient conjugate heat transfer problem scott Siemens 2 March 12, 2007 14:10
time averaged heat transfer in oscillating flow Matthieu Ubas Main CFD Forum 2 November 5, 1999 14:20
