Chemical reaction rate in enthalpy equation
Old   July 16, 2003, 08:40
Default Chemical reaction rate in enthalpy equation
Jianping Zhang
Hi, all:
I'd like to ask a question regarding the chemical reaction term (sometimes it is also called volumetric heat release rate) in the enthalpy equation.
I found that, in most cases when EBU combustion models are used, this term is omitted. Is this omission due to the nature of EBU models. And if i want to take into account this term, do i have to use the LFM combustion model?
Thanks for any advice
Old   July 16, 2003, 10:10
Default Re: Chemical reaction rate in enthalpy equation
mike
With the EBU combustion model the definition of the enthalpy includes the chemical potential, and so no heat release term appears in the enthalpy equation. The term is eliminated by combination of the species and energy equations under the assumption of a simple chemically reacting system(SCRS).
Surface reaction rate temperature dependence tumbao FLUENT 1 February 17, 2011 09:14
UDF for catalyst volumetric reaction, temperature overshoot though rate is small elmcmaster FLUENT 0 October 11, 2010 09:37
Enthalpy equation for multicomponent mixtures alberto_cuoci OpenFOAM 1 October 8, 2009 10:59
surface reaction rate zhou FLUENT 4 October 2, 2003 16:16
surface reaction rate plot at diffusiion limit cas Jason FLUENT 1 August 22, 2003 04:54
