blockMesh error
Old   May 24, 2009, 16:21
Default blockMesh error
JohanOlivier is on a distinguished road
Good day,
When I try to run the cavity tutorial in icoFoam, i get the following error when running blockMesh:
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
Exec : blockMesh
Date : May 22 2009
Time : 23:01:49
Host : johano-laptop
PID : 15708
Case : /home/johano/OpenFOAM/johano-1.5/FOAM_RUN/tutorials/icoFoam/cavity/constant/polyMesh
nProcs : 1
Create time
cannot open file
file: /home/johano/OpenFOAM/johano-1.5/FOAM_RUN/tutorials/icoFoam/cavity/constant/polyMesh/system/controlDict at line 0.
From function regIOobject::readStream(const word&)
in file db/regIOobject/regIOobjectRead.C at line 66.
FOAM exiting
Anyone knows what the problem might be? I cannot find the "..system/controlDict" directory within polyMesh... maybe that is the problem..but how do i get around this?
Thank you.
JohanOlivier is offline   Reply With Quote
Old   May 25, 2009, 03:01
Smile
Ahmed
Ahmed is on a distinguished road
I am not an expert OpenFOAM user, but I checked the directory structure of the cavity problem on my computer, the file you are missing is into the directory /cavity/system/
I guess you need to check your PATH
Let us Know if that helps and Good Luck
Ahmed is offline   Reply With Quote
Old   May 26, 2009, 10:13
N/A
harishg is on a distinguished road
You have to be in the cavity directory when you run the case. The problem is your pwd is polyMesh directory. change your directory and run
not
harishg is offline   Reply With Quote
Old   May 28, 2009, 16:21
Thank you harishg!
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
