September 16, 2003, 02:58 |
stability and accuracy
Hi I am beginner and solving simple second order Heat conduction equation using FTCS and CN method. When can I say, the solution is both stable and accurate, only stable ,and only accureate ? What is the relation between stability and accuracy ?
Thanks in advance regards ravi |
September 16, 2003, 05:27 |
Re: stability and accuracy
I don't think that there is a definition for accuracy. The important realtion is that (under some conditions): Stability + Consistency <=> Convergence. You should look those terms and their meaning up in a text book on numerical analysis for ODEs. Essentially it means that if your scheme is unstable, it is also divergent and dependent on what order of consistency you have, your order of convergence increases. Sort of ;-)
Aerodynamic Stability Derivatives | Andrew Clark | FLUENT | 1 | November 23, 2021 20:19 |
Any questions about Runge-Kutta methods | Runge_Kutta | Main CFD Forum | 33 | September 9, 2019 16:32 |
error when solving gamma equation? | zhajingjing | OpenFOAM | 1 | April 27, 2010 03:32 |
effect of order of temporal accuracy | zonexo | Main CFD Forum | 4 | August 14, 2006 00:36 |
Semi-implicit Runge-Kutta | Bobby | Main CFD Forum | 10 | August 5, 2005 15:43 |
