Finite difference can be non-conservative?
Old   July 8, 2009, 00:56
Default Finite difference can be non-conservative?
greg
gregmason is on a distinguished road
Hello
We know that finite volume methods are always locally conservative (my concern is mass only). I was wondering if that is always the case with finite difference methods too? What about for cell-centered finite difference methods in particular. Also, what if the flow being considered is in anisotropic domain, where flux is not necessarily oriented in the direction of gradient.
Thanks.
gregmason is offline   Reply With Quote
Old   July 8, 2009, 08:33
M. Nabi
mnabi is on a distinguished road
for incompressible flow, in anycase, it must be conservative. It is not related to the type of discretization.
To solve the incompressible flow, people usually use the fractional step method. (Pressure correction method). At this method, the predictor gives non-conservative velocity field. But it gets corrected by the pressure correction. It is not related to the type of discretization. In all kinds of discretizations, the divergence of the velocity, must be zero. The only thing which must be considered, is the discretization of pressure poisson equation, must adapt the velocity discretization. (this problems arise in unstructured grids).
There is another method, namely artificial compressibility method. At this method, pressure correction is not necessary. by adding a term (virtual density) to the continuity equation, and solving the time dependent density. In this case, the velocity is not divergence free per iteration. But to solve time dependent problems, they iterate it per time step, until density converges to the real density. But it is still not related to the type of discretization.
Thus I suggest you to control your solver again.
mnabi is offline   Reply With Quote
Old   July 8, 2009, 11:53
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
however, finite difference schemes are not necessarily kinetic energy conserving, especially when going to higher orders. there should be several papers about this topic availables from the Stanford CTR site (by Morinishi and Vasilyev).
sbaffini is offline   Reply With Quote
anisotropy, finite difference, finite volume, locally conservative
Finite element vs. finite difference Francisco Saldarriaga Main CFD Forum 23 December 17, 2014 08:21
Finite Difference Vs. Finite Volume elankov Main CFD Forum 43 December 18, 2010 16:30
Fininte difference and Finite element Technique Mahendra Singh Mehra FLUENT 3 December 22, 2005 23:49
finite difference method for navier-stokes problem dallybird Main CFD Forum 5 February 17, 2003 22:00
Conservative finite difference scheme? Linfeng BI Main CFD Forum 1 October 10, 2002 12:17
