one dimensional unsteady heat conduction
Old   July 10, 2009, 12:26
Default one dimensional unsteady heat conduction
Vijesh Joshi
vijeshjoshi23 is on a distinguished road
Dear friends,
how to decide time step to solve one dimensional unsteady heat conduction through a slab by implicit scheme ?? I am writing a code in matlab to solve this. I am facing numerical oscillations. Plz help...
vijeshjoshi23 is offline   Reply With Quote
Old   July 10, 2009, 21:22
RenardP is on a distinguished road
You can test your code by marching in time to a steady solution ( for which you can find an exact analytical solution ). Since you use an implicit scheme for your time integration the time step for a steady solution should not be a concern. If your code does not converge to the steady solution you should check again the implementation.
RenardP is offline   Reply With Quote
calculating unsteady heat release due to comb James FLUENT 1 February 27, 2014 20:03
Conduction heat not balanced? Nepal CFX 7 May 31, 2005 11:51
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Heat conduction through solid rib in periodic duct Dieter Fauconnier FLUENT 0 October 7, 2004 08:22
Unsteady Heat Transfer Modeling Muller FLUENT 5 June 7, 2003 01:28
