¡¾Q¡¿inflow turbulence B.C. of k-epsilon model?
Old   October 9, 2003, 22:45
Default ¡¾Q¡¿inflow turbulence B.C. of k-epsilon model?
David
I see some referrences give the inflow tubulence boundary condition as follows:
k=const.
epsilon=Cu^0.75*k(z)^1.5/l (this is the most common style gives epsilon)
l£½(Cu^0.5*k(z))^0.5/d<u>/dz (why???) so: epsilon=Cu^0.5*k(z)*d<u>/dz
My question is: where the expression of epsilon comes from? whether this turbulence condition means turbulence has been in equilibrium ? thanks.
Old   October 10, 2003, 08:04
Default Re: ¡¾Q¡¿inflow turbulence B.C. of k-epsilon model
sylvain
In the log law region :
k=uf^2/Cu^0.5
and k equilibrium means Production of k = Dissipation of k, so
epsilon = Cu k^2/epsilon * (du/dy)^2
with du/dy = uf/Kappa.y = Cu^0.25 k^0.5 / Kappa.y
it comes
epsilon = Cu^0.75 k^1.5 / l , with l = Kappa.y
This is a CONSEQUENCE of the k-eps model.
Old   October 10, 2003, 10:54
David
Thank you,Sylvain.
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 20:21
attachdetach turbulence b.c. Peter_600 OpenFOAM 0 February 14, 2011 04:44
Turbulence Model and limitation to Reynolds number qascapri FLUENT 0 January 24, 2011 10:48
v2-f turbulence model in CFX? flga CFX 14 November 23, 2006 06:12
Turbulence model Herry Phoenics 1 May 29, 2003 13:19
