October 21, 2003, 08:15 |
Code Validation
Hi, I'm working with a commercial CFD package and I'm looking for basic examples that can be used to validate the code. As I'm trying to model highly convective biological flows with large Peclet numbers, I need to validate the upwinding ability of the software to solve these convective flows. Any comments or advice would be greatly appreciated. Thanks
October 21, 2003, 09:20 |
Re: Code Validation
I think You can do something like this. You can discretize convection diffusion equation and use differenet values of Sc number and you can validate your code against analytical results.
Pr |
October 21, 2003, 09:34 |
Re: Code Validation
Thanks. As I'm new to CFD, I was wondering if you knew about upwinding. I'm using a finite element code and all the published work refers to the Streamline/Upwind Petrov-Galerkin (SUPG) upwinding technique. However, the upwinding is applied to the Navier-Stokes equations. If I can validate my upwinding against the published Navier-Stokes work, is it possible to assume that the upwing technique is valid for the convection diffusion equation? Again, any advice would be of great help
October 22, 2003, 06:50 |
Re: Code Validation
Hi dev
I was wondering if you knew about upwinding. I'm using a finite element code No I do not know anything about finite elemnt codes and all the published work refers to the Streamline/Upwind Petrov-Galerkin (SUPG) upwinding technique. However, the upwinding is applied to the Navier-Stokes equations. If I can validate my upwinding against the published Navier-Stokes work, Why do not you validate your results ith convection reaction diffusion equation it would not take muc time i guess is it possible to assume that the upwing technique is valid for the convection diffusion equation? Again, any advice would be of great help Pr |
October 22, 2003, 06:54 |
Re: Code Validation
Thanks for the advice Pr
code validation | Ma | Main CFD Forum | 8 | February 14, 2002 10:25 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
own Code vs. commercial code | Bernhard Mueck | Main CFD Forum | 10 | February 16, 2000 10:07 |
State of the art in CFD technology | Juan Carlos GARCIA SALAS | Main CFD Forum | 39 | November 1, 1999 14:34 |
