September 9, 2009, 09:25 |
k-e model limits
fateme chegini
Rep Power: 16 |
Hi
I'm trying to implement the k-e model in my code. The problem is I don't know what is the limiting value for k and e. In some problems the min values I use (ie:kmin=10^-6 & emin=10^-5) yield to correct answers but when the geometry is very unregular my model becomes unstable and the viscosity grows. I would rather not put an upper limit for k although I know this is conventional. Do you think I can do that or am I obliged to implement a max bound for k or viscosity? Does anyone know of a good refrence that has discussed about the limiting values of k and e? Thanks very much. |
September 9, 2009, 13:45 |
Rep Power: 17 |
I have the same situations, sometime the ratio of k/e play a big role.In my case, in some regimes, the velocity is very small and also the strain rate.. etc, and K and E are reasonable values (very small). But the eddy viscosity have a big value due to K**2/E.
Can anyone give some suggestions? |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
references about the fan/radiator model | Mihai ARGHIR | Main CFD Forum | 1 | January 8, 2001 15:49 |
references about the fan/radiator model | Mihai ARGHIR | Main CFD Forum | 0 | December 21, 2000 03:06 |
references about the fan/radiator model | Mihai ARGHIR | Main CFD Forum | 1 | December 17, 2000 07:01 |
references about the fan/radiator model | Mihai ARGHIR | FLUENT | 0 | December 17, 2000 06:40 |
