November 20, 2003, 17:46 |
Re: period BC in streamwise.
I don't think you can use periodic boundary conditions for your problem as stated. As you note, there will be a pressure drop along the section and periodic b.c. would result in multivalued pressure and density.
I can imagine using periodic b.c. if you had a nonconservative body force like an electromagnetic pump driving the flow, in which case the pressure gradient could be zero and so the inlet and outlet pressures would match. You would not specify initial or inlet flow as the solution should evolve to fully-developed Poiseulle flow over time. |
dosing period | wlt_1985 | FLUENT | 2 | January 4, 2011 22:19 |
Streamwise Second Derivatives | S. | CFX | 3 | October 4, 2007 02:16 |
Convergence issues with long period sloshing flows | Brian | FLUENT | 1 | February 1, 2006 08:41 |
Period BC turb. channel | Guus Jacobs | Main CFD Forum | 7 | December 21, 2001 13:58 |
I look for an engineering training period | Jean-Michel DESERT | Main CFD Forum | 1 | October 3, 1998 00:24 |
