refine unstructured mesh
Old   January 11, 2004, 07:11
Default refine unstructured mesh
s
any body know about how to refine unstrurd mesh in gambit at particular location
Old   January 12, 2004, 09:15
Default Re: refine unstructured mesh
Jeff Franklin
As far as I know this is not possible
Old   January 12, 2004, 09:39
s
but in the gambit manual it is writen that it is possible
Old   January 12, 2004, 18:46
xueying
I refine mesh by generating volume base base on surface mesh and surface mesh on line mesh. We can define the mesh density on line mesh.
Old   January 12, 2004, 22:54
s
is there any method that we refine at particular location
Old   January 21, 2004, 18:56
Jim Clancy
It is possible to refine the mesh in Gambit. All what you will do is to create another voulme just in where you want to refine and then split the original volume ( use connected option ) using this new volume. Therefore, mesh the small volume first with fine mesh and then mesh the rest of the domain. Export it to Fluent and ENJOY YOUR TIME..Good Luck
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[ICEM] Unstructured mesh refinement in ICEM lost.identity ANSYS Meshing & Geometry 3 April 28, 2013 11:10
[Commercial meshers] Unstructured hex mesh lr103476 OpenFOAM Meshing & Mesh Conversion 12 November 24, 2006 05:56
