C++ solver for Large sparse matrix!
Old   November 18, 2009, 09:17
Exclamation C++ solver for Large sparse matrix!
SinaJ
sina_mech is on a distinguished road
Hi
I have a large sparse matrix (generated by Poisson Equation in my own C++ Code). I'm looking for a EASY TO EMBED AND USE, fast Sparse solver, witch can receive matrix of elements in sparse modes (to use lesser memory), and solve it by any of common fast methods (like Gmres, Bicgstab and ...).
I'll appreciate if anyone can help me
GoodLuck
sina_mech is offline   Reply With Quote
Old   November 19, 2009, 09:43
walli is on a distinguished road
Consider using PETSc for your code! Even though it is (in my opinion) ugly C code, one can fairly easy write a rudimentary C++ interface if needed. It is really fast, tested and provides a big variety of solvers and preconditioners. Another possibility would be mtl4, which is written in C++, fast, but unfortunately still in alpha development stage. But why do you want to use GMRES, BiCGSTAB and so on? You system is symmetric and positive definite, so use a (preconditioned) CG solver for this.
walli is offline   Reply With Quote
Old   November 20, 2009, 02:52
Dominic Chandar
dominic is on a distinguished road
Send a message via Skype™ to dominic
I would use PETSc for this. Moreover, application of boundary conditions, and/or sources can disrupt the symmetry of the matrix. Thats why probably you cannot use CG.
Dominic
dominic is offline   Reply With Quote
Old   November 20, 2009, 08:40
Sure, that's true. But this clearly depends on the way you incorporate the BC's. A way to do this symmetrically would be e.g. a penalty method.
Old   November 20, 2009, 12:19
jed
Jed Brown
jed is on a distinguished road
Penalty is a bad choice with some preconditioners, or if the system is very ill-conditioned. The best way is to remove the Dirichlet degrees of freedom, either explicitly, or by making both] the row and column equal to the identity (with appropriate modification of the right hand side). This is easy to do, especially when using Newton-type iteration, but people still manage to write code in a way that makes this hard. Note that many good preconditioners are nonsymmetric sometimes enough better than the symmetric alternatives to justify using a nonsymmetric Krylov method.
jed is offline   Reply With Quote
Old   November 20, 2009, 12:23
jed
Jed Brown
What do you dislike? Perhaps I can explain why certain things are the way they are.
Old   November 20, 2009, 13:23
That was more about C style programming than PETSc. Speaking about PETSc, I particularly don't like the inflationary use of the CHKERR-stuff. But don't get me wrong! It is a great library and it does its job very good!
Old   November 20, 2009, 13:52
jed
Jed Brown
Note that while it is written in C, it is very much object oriented. PETSc objects use a variant of the delagator/pimpl pattern, but see object creation is (by default) managed by an inversion of control known as dependency injection. You might have heard of this in the context of frameworks like Spring. This has the advantage that your code never makes explicit reference to the implementation of your objects, just the interface that they implement. With this design, it is natural that every object has a plugin architecture. That is, you can compile a preconditioner and custom matrix format to a shared library send it to someone else who does not have source for anything, and they can select your preconditioner at run time just like the ones distributed with PETSc.
Yes, I don't even see them anymore. The reason for this (and a couple other macros used within PETSc) is mostly to be able to get full stack traces when something goes wrong, as well as to detect memory corruption and leaks. C++ exceptions have serious interoperability problems and lack the semantics required to get reliable stack traces in parallel, as well as to automatically attach a debugger on the site where the error occurred (even in parallel). You certainly don't have to use these macros, but they really do make debugging easier.
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
free C code for large sparse matrix linear solver ztdep Main CFD Forum 7 May 24, 2007 14:14
problem about direct solver for sparse matrix ztdep Main CFD Forum 0 August 11, 2006 12:16
Aztec - sparse matrix paralell solver Astrid Main CFD Forum 7 August 3, 2001 12:41
solver for linear system with large sparse matrix Yangang Bao Main CFD Forum 1 October 25, 1999 04:22
