November 20, 2009, 14:56 |
verifying second order
vahid
hi
I have written a code for wave equation with RK2. now I want to know how I can be sure that my code is second order? the error must be smaller than what? |
November 20, 2009, 16:34 |
Jed Brown
Rep Power: 19 |
Which wave equation? In any case, you choose a smooth solution ( is good) and compare your code's results at successively finer resolution (refine in both space and time). Now plot versus , the resulting slope is the order of accuracy of your method. If you don't have an exact solution available, you can manufacture one by introducing a distributed source term that makes something simple a solution, or (generally a worse option) compute a reference solution at very high resolution (preferably with a proven code).
November 23, 2009, 16:51 |
code order
Hi there,
Do richardson extrapolation test for grid convergence! 3 sets of results at time steps or spatial step h, h/2 ,h 4 is needed (basically 3 grids). works for structured mesh straight up ! Unstructured meshes are tricky. Since yours is a simple RK based integration procedure method..this works very well. /CFDtoy |
IS calc. with 2nd order discret. always necessary? | Azman | FLUENT | 2 | March 14, 2013 04:28 |
1st order vs 2nd order | ken | FLUENT | 8 | March 14, 2013 03:43 |
Unstable flow simpleFoam 2nd order | Valle | OpenFOAM | 0 | August 26, 2009 08:12 |
CFL condition for higher order schemes | Shyam | Main CFD Forum | 2 | February 14, 2008 14:24 |
SECOND ORDER DON'T CONVERGE, WHY?????????? | naus | FLUENT | 10 | March 13, 2006 07:21 |
