Modeling marine propeller in fluent
Like Tree1Likes
  • 1 Post By Lukasz Skraburski
Old   January 24, 2004, 10:47
Default Modeling marine propeller in fluent
Lukasz Skraburski
Hi, I'm trying to simulate flow around a propeller. The propeller is rotating, so I'm fixing it and rotating water instead of propeller. I'm using single rotating reference frame. I don't know if this is cgrrect, results are not OK. How big should be domaind for a propeller D=0.3048m My is r=6m, 3m upstream, 10m downstream.
If anybody know how to do this, please help. Thanks Lukasz
ema_amalia likes this.
Old   January 24, 2004, 12:43
Default Re: Modeling marine propeller in fluent
Joern
You have to use at least multiple rotating frames. If you want to calculate the interaction between the ship hull and the propeller you have to use sliding mesh.
Old   January 25, 2004, 06:19
Li Yang
I don't know much about Fluent but if he only simulates a single propeller and does not want to take into account the interaction effects between the propeller and the hull, an attached blade frame can be used, and the flow around a propeller can be regarded as a steady flow.
Old   January 25, 2004, 12:45
James Date
You want to check out the research done by Moustafa Abdel-Maksoud on CFD propeller modelling. There's lots of references on the web.
James
Old   January 25, 2004, 13:08
Lukasz Skraburski
I'm modeling only the propeller, I got problems at advance coefficient about J=1.1 and higher.
Multiphase flow modeling: CFX or FLUENT? Paul Main CFD Forum 8 January 24, 2012 09:25
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 13:43
Contact modeling in FLUENT pchama1 ANSYS 3 May 27, 2011 16:34
modeling in fluent amir FLUENT 2 December 12, 2005 01:43
Fluent modeling capability Jane Luo FLUENT 1 April 27, 2004 10:42
