January 27, 2004, 22:10 |
Looking for the experimental data
Hi, everyone,
I'm looking for the experimental data of back-step flow to compare with the numerical results. I have some papers about back-step flow, but most of them didn't have clear figures to digitize the experimental data. Does anyone have the experimental data or know which paper has clear figures about the experimental data? Thanks everyone |
January 28, 2004, 02:49 |
Re: Looking for the experimental data
Try ERCOFTAC "Classic Collection" Database on http://cfd.me.umist.ac.uk/ercofold/, cases c30 (experimental) and c31 (DNS solution). If you cannot access the "available measurement/result" section (authentication needed), you can at least search for the original references:
c30) DRIVER, D.M. & SEEGMILLER, H.L. (1985). Features of a reattaching turbulent shear layer in divergent channel flow. AIAA J. 23, 163, (category No. 59.0: good LDV data but no w, b85-0082). c31) LE, H. & MOIN, P. (1992). Direct numerical simulation of turbulent flow over a backward-facing step . Stanford Univ., Center for Turbulence Research, Annual Research Briefs, pp.161-173. |
January 28, 2004, 23:38 |
http://www.grc.nasa.gov/WWW/wind/valid/validation.html
In this site, results of exp. data and simulation with some turbulence models are given. Best regards. |
Tecplot. add experimental data into a mesh | Alejandro | FLUENT | 0 | December 10, 2008 07:08 |
Experimental data on transition | kepler | Main CFD Forum | 2 | October 24, 2007 03:13 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
Simulated data vs. experimental data | moiami | FLUENT | 0 | December 19, 2002 01:03 |
Experimental data for fence at low Reynolds number | Kim Bindesboll Andersen | Main CFD Forum | 1 | September 26, 2002 13:54 |
