Jameson's scheme for LES ?
Old   February 23, 2004, 18:25
Default Jameson's scheme for LES ?
Li Yang
Dear all,
as we know that the central difference scheme is popular and a common practice for incompressible flow LES, I wonder if Jameson's central difference scheme is also OK for compressible flow LES. Why or why not ? Any references ?
Thanks for your reply in advance.
Li Yang
Old   February 23, 2004, 22:53
Default Re: Jameson's scheme for LES ?
Bin Li
I used the TVD scheme with convective term and central difference scheme in the viscous term. I'm studying the compressible LES.
Old   February 23, 2004, 22:57
Apurva
I have not tried Jameson for LES, but have used it for incompressible NS. It Works well. Just switch off the shock capturing dissipation terms, At present I am not exactly remembering it. I will give the answer in 1-2 days time.
Best of Luck
Apurva
Old   February 24, 2004, 04:45
Li Yang
Hi Apurva,
Jameson's scheme is indeed OK for relatively low speed flow simulation. What did you mean "switch off the shock capturing dissipation term" ? As far as I know, Jameson's central difference scheme consists of a central differencing term and two artificial viscosity terms.
Kind regards
Li
Old   February 24, 2004, 05:28
Li Yang
as far as I know, most of people using high order (3rd or 5th order) upwind schemes for compressible flow LES. But those schemes are found still very dissipative.
Therefore, I would like to know whether Jameson's central difference scheme will be OK for compresible flow LES where there is no strong shock.
Old   February 24, 2004, 07:11
Apurva
Their are second order and fourth order dissipative terms. One of them is meant for damping the osscilations and avoiding checker-board solution. While second is used for shock capturing and avoiding failure of central difference scheme at Mach 1 (where normal central difference scheme will fail).
Please read Jameson, Turkel and Skmidt's paper carefully.
Old   February 24, 2004, 07:49
Apurva
I have a suggession, go through 1997 AIAA Journal, there is a paper by Jonathan Wises (I am not sure of spelling) on preconditioning. Try that method.
Old   February 24, 2004, 13:40
Li Yang
Thanks a lot. I have some further questions about Jameson's scheme, as I wonder how large these artificial viscocity terms could be, compared to the real viscous terms. In addition, can these two artificial viscous terms be switched off for a RANS calculation in a subsonic case ? Will this makes possibly a stable and less dissipative numerical scheme ?
Old   February 25, 2004, 13:02
tp
Implicit Solution of Preconditioned Navier-Stokes Equations Using Algebraic Multigrid.
Author(s): Jonathan M. Weiss; Joseph P. Maruszewski; Wayne A. Smith
Source: AIAA Journal (American Institute of Aeronautics and Astronautics)
Year: 1999 Volume: 37 Number: 1 Pages: 29-36
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
When to use upwind or central differencing schemes? quarkz Main CFD Forum 6 August 19, 2011 03:24
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
Definition of limiter function for central dirrerencing scheme sebastian_vogl OpenFOAM Running, Solving & CFD 0 January 5, 2009 11:08
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 11:21
