What's the difference between a linear and a nonlinear solver?
Like Tree1Likes
  • 1 Post By taw
Old   February 4, 2010, 18:46
Default What's the difference between a linear and a nonlinear solver?
bearcat
bearcat is on a distinguished road
Send a message via MSN to bearcat
Recently I met with these two names.
I think that should be an easy question. I search this forum but cannot find the answer. Could anyone answer that?
bearcat is offline   Reply With Quote
Old   February 5, 2010, 07:11
taw
taw is on a distinguished road
I think a non-linear solver uses a newton-raphson like iterative solver. That is at each iteration you need to find the jacobian of the solution matrix.
If the solution matrix is dependent on the the fluid states, example the pressure is dependent on the temperature field (typical compressible flow), you need this type of solvers. In that case you need to supply the equation of state.
In incompressible flow, the coefficient matrix are not strongly dependent on the (thermodynamic) states of the flow variables, so linear solvers suffices.
My 5 cents
Cheers
granzer likes this.
taw is offline   Reply With Quote
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Getting too many iterations by velocity solving (aborting). Changing U - Solver? suitup OpenFOAM Running, Solving & CFD 0 January 20, 2010 07:45
desperate Fatal overflow in linear solver - transient kingjewel1 CFX 9 January 5, 2010 13:53
Linear system solver elias FLUENT 0 November 19, 2008 09:30
solver for linear system with large sparse matrix Yangang Bao Main CFD Forum 1 October 25, 1999 04:22
