3-D geometry problem using Gambit [pls help]
Old   March 20, 2010, 07:20
Default 3-D geometry problem using Gambit [pls help]
veronicayeo is on a distinguished road
Hi there,
I'm trying to draw this orifice using gambit (as attached image), and so far I couldnt figure out a way to draw it. Basically the "black rectangular shapes" are perforations on a single plate. I know the size of each of the perforations but just dunno how i should arrange them in such an arrangement.
Does anyone have any suggestions? Thanks.
veronicayeo is offline   Reply With Quote
Old   March 20, 2010, 10:20
DoHander is on a distinguished road
you have 3 concentrical "rows", take for example the internal circle, draw manually one of the shape and copy and rotate this 10 times (or the number of holes for this circle). Probably you have equal spaces between the holes, so you can use some constant angle increment like 360/10=36 degree for the internal circle.
Same for the other 2.
Do
DoHander is offline   Reply With Quote
Old   March 21, 2010, 09:33
hmm... will try using the angles.... thx =)
Mesh geometry over airfoil with Gambit laith FLUENT 5 March 9, 2018 01:56
Question: Geometry file for Gambit yueke FLUENT 0 May 28, 2009 09:55
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
IGES to Gambit Problem A. Al-Witry Main CFD Forum 7 June 30, 1999 07:15
