March 26, 2010, 14:06 |
Radiation problem
Rohit Koolwal
Rep Power: 16 |
Please look at the problem statement in the post below...I need to solve it urgently...plzzzz help me!!!!
March 28, 2010, 13:41 |
Rohit Koolwal
Rep Power: 16 |
Hi everyone!!!
I didn't got the reply to the above question. I want to elaborate a bit about exactly what I have done and the changes done to the above mentioned simulation. I am simulating moderator flow over a nuclear fuel rod. I have taken an enclosure surrounding by 3 rods to make a polygon which has one inflow and one outflow. I have set velocity inlet at the inflow and pressure outlet BC at the outflow. At the surfaces a constant temperature of around 1200 K has been applied. DO radiation model has been used in the simulation. After performing the simulation I found that the radiative heat flux is small while the total heat flux is very large(order of 3 more). But at such a high temp. radiation should be the dominant mode of heat transfer(total heat flux should be approx. equal to radiative heat flux for each surface as convective heat will be very less as compared to radiative)?? I am perplexed looking at the result. Please help me out of this. I need to solve this simulation asap. In anticaipation of a reply !!!! |
Radiation problem | Rahul Hiwale | FLUENT | 7 | July 30, 2022 03:48 |
wall emissivity for radiation problem: emitter is also receiving when it shouldn't | Young | FLUENT | 14 | January 7, 2016 06:08 |
How to solve this problem about radiation? | Mr. Lee M-S | FLUENT | 2 | December 20, 2001 12:02 |
About Radiation | BNLOO | Siemens | 0 | September 5, 2001 08:35 |
Cool system ,Convection + Radiation problem. | Leo | FLUENT | 1 | February 21, 2001 03:39 |
