December 7, 2012, 12:58 |
NACA0012 airfoil Critical reynolds number
Kianoosh
Rep Power: 13 |
hi guys
i need a resource for critical Reynolds number over NACA0012 and NACA0015 and NACA0018 airfoils. I search a lot but i can't find a paper or part of book that report these numbers. can any body help me and recommend me a valid resource. thx |
December 7, 2012, 14:31 |
sajid
Chaudhary
Rep Power: 13 |
dear it can be calculated by using hydraulic dia meter
December 7, 2012, 17:43 |
Kianoosh
Rep Power: 13 |
December 7, 2012, 18:34 |
Rep Power: 18 |
If you are trying to establish the transition point, the first approximation is to use the flat plate value of Re = 500000, where the distance is measured from the nose of the airfoil (or the attachment point for high angles of attack). Googling critical Reynolds airfoil may provide you with more info.
December 7, 2012, 18:45 |
#5 | |
Kianoosh
Rep Power: 13 |
in angle of attack of 0 degrees we don't have a separation point on NACA 0012 airfoil (i use the fluent for simulation) at re=500,000 , it that mean the flow is laminar. but it shouldn't be correct, because over the flat plate the flow is turbulent for re>500,000 and on the airfoils we have thickness on the critical Reynolds number should be smaller. is it correct? otherwise in the Huang et al. work (2004), this is my base type for validation, the flow with re=500,000 was introduced fully turbulent flow over NACA0012 airfoil. |
December 7, 2012, 22:58 |
Rep Power: 18 |
I'm not sure what you are saying here, but laminar flow over a NACA0012 will separate. Like I said, Re = 500000 is only a rough guide. For more info you could look here
www.risoe.dk/rispubl/VEA/veapdf/RIS-R-987.pdf if this link works. I found it by googling "critical reynolds number airfoil" |
December 8, 2012, 07:39 |
Kianoosh
Rep Power: 13 |
December 8, 2012, 08:28 |
#9 |
It is extremely easy to lern and use. Google x-foil tutorial or x-foil manual
or look at Session for NACA0012 will look as follows: opening x-foil you will get prompt XFOIL c>, you just enter naca0012 like this XFOIL c> NACA0012 + enter the x-foil will generate naca0012 coordinates and will print the foil description followed by XFOIL prompt, then you put XFOIL c> OPER + enter you will get new prompt .OPERi, it means that you entered flow analysys subroutine. Then you put .OPERi c> visc 5E5 + enter i.e. you fixed your reynolds number to 500K and you will get prompt OPERv then you put .OPERv c> alfa 0 +enter it means your angle of attack is 0: the xfoil will show you analysys data, if it writes that computation does not converce, put again alfa 0 etc unil it converges. If you want re-initialize computations put init To exit from analysys subroutine (or any other sub-routine) to higer level routine just press enter. To change free stream turbulence parameters enter .OPERv c> vpar + enter you will get prompt VPAR. By default Ncrit=9, to decrease free stream turbulence put higer Ncrit, e.g. ..VPAR c> N 15 + enter then just press enter to return to OPERv and put your alfa For help press ? + enter To see transition and separation points use command ..OPERv c> vplot + enter you will get prompt VPLO Then put ...VPLO c> CF + enter you will see plot Cf vs X, the point where Cf=0 is the separation point |
December 8, 2012, 09:16 |
#10 | |
Kianoosh
Rep Power: 13 |
December 9, 2012, 22:43 |
#11 |
Mehdi Baba Mehdi
Rep Power: 15 |
Dear Kianoosh;
I don't want to make you confused, but it is so hard to say the exact Re in which transition starts. It depends on a lot of parameters, such as turbulence intensity, pressure gradient. |
December 10, 2012, 01:15 |
#12 | |
Kianoosh
Rep Power: 13 |
i try to define th critical Re in this way. for naca0012 airfoil i starting to found the separation point from Re=5e5. in this Re number the separation point was at aboiut 0.85 C. I try with different Re Number 4e5, 3e5, 2e5, e5, 8e4 until the flow over airfoil to be laminar or separation point be in 1. this mean is we don't have any separation on the airfoil surface at Critical Re. i the Critical Reynolds Number for NACA0012 about e5 and for NACA 0015 about 3.5e4. whats you idea? |
December 10, 2012, 02:43 |
#13 |
Mehdi Baba Mehdi
Rep Power: 15 |
Dear kianoosh;
I recommend you to read "Boundary-Layer Measurements on an Airfoil at Low Reynolds Numbers" by M. Brendel. it is very helpful paper in describing transition and how it can be found out where flow starts laminar to turbulent transition. I hope it can answer your questions. |
December 15, 2012, 09:04 |
#14 |
Choose one...
Rep Power: 13 |
Is the paper by Brendel available online.
If yes, kindly post the link. else kindly mail me at debanik1@gmail.com |
December 15, 2012, 11:07 |
#15 | |
Kianoosh
Rep Power: 13 |
December 15, 2012, 11:10 |
#16 |
Choose one...
Rep Power: 13 |
December 15, 2012, 11:18 |
#17 | |
Kianoosh
Rep Power: 13 |
January 14, 2014, 09:51 |
#18 |
Rep Power: 17 |
please, send to vaina74@hotmail.com.
thanks. |
December 15, 2012, 11:15 |
#19 | |
Kianoosh
Rep Power: 13 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
reynolds number averaging?? | qrie | Main CFD Forum | 0 | June 26, 2010 03:46 |
critical Reynolds number | jag | Main CFD Forum | 4 | December 4, 2006 22:26 |
Critical Reynolds Number | Dipankar Chatterjee | Main CFD Forum | 0 | September 4, 2002 10:01 |
