May 12, 2004, 01:39 |
Fast Fourier Transformation
Hi all, I am searching documents concerning the theory and the application of fast fourier transformation. I have no experience with it, but should be able to use it as soon as possible. So I am searching a book or something which is easy to understand.
Can somebody help me? Thank you in advance m.stein |
May 12, 2004, 02:13 |
Re: Fast Fourier Transform
Have a look in Numerical Recipees. It is available online (http://www.nr.com/).
May 12, 2004, 13:10 |
If you just want to do FFT and need a tool, I suggest you to use Matlab. FFT is also introduced in its manual.
May 13, 2004, 01:55 |
Re: Fast Fourier Transformation
Fundamentals of engineering numerical analysis. by Parviz Moin.
May 16, 2004, 11:20 |
Thanx, for your hints
Fast Fourier Transform | alastormoody11 | STAR-CCM+ | 0 | January 20, 2011 22:49 |
Fast Fourier Transform of CL signal | Sachin Paramane | Main CFD Forum | 0 | June 11, 2007 07:51 |
Fast Fourier Transform | Lourival | Main CFD Forum | 21 | June 7, 2007 00:53 |
Fast Fourier Transform | Lourival | FLUENT | 0 | May 16, 2007 14:02 |
Fast Fourier Transform | Sara | Main CFD Forum | 2 | February 14, 2006 07:51 |
