February 8, 2017, 11:13 |
#21 | |
Ricardo Ferreira
Rep Power: 10 |
In fact, simulations without wall functions you should keep y+ close unity. Try use "nutLowReWallFunction" in type of nut boundary condition in wall regions. In inlet you can use "calculated" type. Take especial attention to set wall BC in k/epsilon/omega Dict files. Use kLowReWallFunction, epsilonLowReWallFunction, omegaWallFunction, respectively, for wall BCs for k, epsilon and omega dict files. For inlet BC type i used turbulentIntensityKineticEnergyInlet, turbulentMixingLengthDissipationRateInlet, turbulentMixingLengthFrequencyInlet for k, epsilon and omega, respectively. If something is not clear let me know. Cheers. |
February 8, 2017, 11:47 |
#22 | |
Fredi Cenci
Rep Power: 9 |
So, on walls where I do NOT want to use wall functions (y+<1) I should set LowReWallFunction instead fixedValue? best regards, |
February 8, 2017, 13:43 |
#23 |
Ricardo Ferreira
Rep Power: 10 |
Yes. As far as I know, this type of BC allows integration up to wall. Besides, it can be used if you use wall functions too (it is automatic, you can use with or without wall functions). Therefore, who determines whether it will be or not integrated up to the wall is nut BC. Resuming, if you use a Low Reynolds Number Turb. Model to calculate nut you should use the same type of BC based on Low Reynolds for k and epsilon. Evidently, the models that use omega are already built in the concept of Low Reynolds models, so there is no Low Re in yours BC denominations (notice the name of BC: "omegaWallFunction").
February 8, 2017, 14:27 |
#24 | |
Fredi Cenci
Rep Power: 9 |
Now I changed to epsilonLowReWallFunction; kLowReWallFunction; and nutLowReWallFunction with values of the internalField.. seems like it is converging.. thanks a lot! Best Regards, |
May 9, 2017, 01:53 |
#25 |
AmolG
Rep Power: 9 |
Dear William,
What did you get after using k-omega SST model with low Reynolds Number correction? Regards! -Amol |
August 10, 2017, 09:35 |
#26 |
Vino
Rep Power: 13 |
Dear fredicenci,
Are you able to solve k-epsilon or any other model with out wall function (y+<1). My simulation shoots up without wall function. thank you. |
August 10, 2017, 11:36 |
#27 |
Fredi Cenci
Rep Power: 9 |
Yes. You can use lowReynolds wall functions.
Another alternative is to set the values of k,and omega (or epsilon) on the wall. In this case you should use fixedValue. best, Fredi Cenci |
August 11, 2017, 15:41 |
#28 |
Vino
Rep Power: 13 |
November 5, 2017, 22:40 |
#29 |
Harshal Akolekar
Rep Power: 9 |
Great! Great!
February 17, 2018, 11:25 |
selection of Turbulence model
#30 |
Syed Waqar Mehdi
Rep Power: 10 |
Hello
I am currently doing a project regarding analysis on airfoil of Vertical axis wind turbine , I have already researched about many turbulence models like realizable K-epsilon , RNG K-Epsilon, spalart allmaras and K-Omega SST but which should i select and on what basis. Please help me about this |
February 17, 2018, 11:53 |
#31 |
Syed Waqar Mehdi
Rep Power: 10 |
Hello
I am currently doing a project regarding analysis on airfoil of Vertical axis wind turbine , I have already researched about many turbulence models like realizable K-epsilon , RNG K-Epsilon, spalart allmaras and K-Omega SST but which should i select and on what basis. Please help me about this regards Waqar Mehdi shahwaqar36@gmail.com |
September 9, 2018, 18:44 |
#32 | |
Federico Agustín Caccia
Rep Power: 10 |
November 6, 2018, 04:13 |
Menter's SST k-omega turbulent model
#33 |
Nina Philipova
Rep Power: 13 |
Dear Users of ANSYS Fluent,
I have to apply Menter's SST k-omega turbulent model in Fluent for simulating wall bounded tortuous channel. I looked through Fluent User's Guide and Menter's publications: Menter, F. R. (1994), "Two-Equation Eddy-Viscosity Turbulence Models for Engineering Applications", AIAA Journal, vol. 32, no 8. pp. 1598-1605 Menter, F, Kuntz, M., Laugtry, R., Ten years of industrial experience with SST Turbulence model ,Turbulence, Heat and Mass Transfer 4. The cited constants in Fluent User's Guide are different from those in Menter' publications and the sites of NASA, Wikipedia. Could some one help me which constant I have to use? I will be grateful to you so much! |
November 6, 2018, 07:21 |
#34 |
Nina Philipova
Rep Power: 13 |
Constants are the same. Fluent constants are reciprocal to the constants in Menter's publications
December 16, 2018, 10:16 |
#35 |
Lee JP
Rep Power: 7 |
March 21, 2019, 04:56 |
#36 | |
ahmed
Rep Power: 10 |
As u referred to DES model, LES is quite computationally expensive compared to any RANS model. It depends on your problem and also depends on the degree of accuracy which you want to achieve. Even LES needs a turbulence model to be used. For some problem LES might take the solver few weeks to be solved, Actually few weeks definitely accepted compared to its fantastic results and its time saving compared to DNS solvers ofc. However, RANS are widely used as most of industrial proposes are not interested in the deep details of the flow fluctuations so they prefer to averaging the flow properties. |
March 21, 2019, 05:13 |
#37 |
ahmed
Rep Power: 10 |
Hello there,
With respect to ur question, it depends on your application and i highly recommend you to read Klaus A. Hoffmann, Computational Fluid Dynamics Vol. III from page 54 to 65, just 11 pages. In brief, I quick read a presentation before for a prof in some college, i really can't remember it, in which he recommended to use k-epsilon models for free-shear layer flows, external flows, small pressure gradient flow. While the k-omega model are better for internal flows and near wall behavior. SST k-omega merges the advantages of the two previous models. However the computational cost increases with using Spalart- Allmaras model, St. K-epsilon, RNG k-epsi, Realizable k-epsi, Standard k-omega, SST k-omega models, respectively. Although it is recommended to use two or more models on the same application and compare their results so that u can be sure that the model which u chose is gonna work. |
June 24, 2019, 10:08 |
#38 | |
abdo
Rep Power: 7 |
hello brother I'am simulate the swirl flow and I have many problem.. could you help me? |
September 17, 2019, 03:05 |
k-w (wicox, BSL, SST) Vs. k-e
#39 |
Here are some takes from my blog posts about the two families of turbulence models:
k-w: https://cfdisraelblog.wordpress.com/...%89-sst-model/ k-e: https://cfdisraelblog.wordpress.com/...odel%ef%81%a5/ And also the subject of wall-treatment, which is of most importance in it of itself: https://cfdisraelblog.wordpress.com/...-ansys-fluent/ |
March 19, 2020, 18:27 |
#40 |
I love turbulence. Knowing how to model it in just the right fidelity is an art imho. An art I fell in love with 💕
The intention of this set of posts is to embark on a journey of connecting the dots between CFD and turbulence modeling with the phenomenological and practical concepts of engineering turbulence… Even though it will by no means be all encompassing nor highly accurate I hope for the essence to be captured, and even more so communicated… ✨ https://allaboutcfdtomers.blog/2020/...-can-eat-menu/ |
Bounding epsilon or bounding omega | Stylianos | OpenFOAM | 8 | February 23, 2018 13:41 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
Standard K Epsilon and Transitional SST models | Robin | FLUENT | 1 | January 17, 2010 18:06 |
Use of k omega turbulence model | john_w | OpenFOAM Running, Solving & CFD | 2 | September 22, 2009 05:15 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
