Reason for asymmetry in symmetric geometries
Old   June 10, 2010, 02:20
Default Reason for asymmetry in symmetric geometries
doubtsincfd is on a distinguished road
say I have a symmetric geometry like a circular cylinder. the grid is perfectly symmetric around the cylinder and the inlet profile is also symmetric. still why do we get alternate vortex shedding? what is the numerical reason?
in real life scenario there is some asymmetry in the inlet flow which might trigger the asymmetric vortex shedding. but why does this happen in a perfect cfd simulation?
doubtsincfd is offline   Reply With Quote
Old   June 10, 2010, 08:13
agd
agd is on a distinguished road
It is true that in real life there may be some asymmetry that can trigger an asymmetry in a flow, which might not happen in a "perfectly" symmetric CFD simulation. But no CFD simulation is perfectly symmetric, due to such things as round-off error. Also, you are failing to consider the possibility that the Navier-Stokes equations can support solutions that are time-varying and only symmetric in a time-averaged sense.
agd is offline   Reply With Quote
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Why is the solution not symmetric? Hp FLUENT 0 February 2, 2007 14:47
symmetric flow around fuselage Christoph FLUENT 0 November 3, 2005 05:50
Gambit - Virtual Geometries (Pro's & Con's) James Date FLUENT 3 August 11, 2003 15:46
Symmetric problem - Assymetric results Mark Phoenics 2 July 2, 2001 09:04
