How to derive this simple stress tensor calculation?
Old   July 4, 2010, 12:33
Default How to derive this simple stress tensor calculation?
bearcat
bearcat is on a distinguished road
Send a message via MSN to bearcat
Most turbulence models are written in tensor expressions so we have to write out the full formulation before we can implement them. I am not very experienced in difficult tensor analysis. So can anyone explain a little about writing this term in the standard k-e model?
LHS=S_{ij}\frac{\partial U_{i}}{\partial x_{j}}=(\frac{\partial U_{i}}{\partial x_{j}}+\frac{\partial U_{j}}{\partial x_{i}})\frac{\partial U_{i}}{\partial x_{j}}
From other books, the LHS should equals RHS, which reads:
RHS=2[(\frac{\partial u}{\partial x})^{2}+(\frac{\partial v}{\partial y})^{2}+(\frac{\partial w}{\partial z})^{2}]+(\frac{\partial u}{\partial y}+\frac{\partial v}{\partial x})^{2}+( \frac{\partial u}{\partial z}+\frac{\partial w}{\partial x})^{2}+(\frac{\partial w}{\partial y}+\frac{\partial v}{\partial z})^{2}
How to get from LHS to RHS? In my understanding, for 3D domain LHS should be a 3x3 matrix as it's a product of two rank-two tensors. But RHS is a scalar. How can this happen?
Thank you very much.
bearcat is offline   Reply With Quote
Old   July 4, 2010, 13:46
Administrator
jola's Avatar
Jonas Larsson
jola is on a distinguished road
Send a message via MSN to jola Send a message via Skype™ to jola
Check out: http://www.cfd-online.com/Wiki/Einst...ion_convention
The LHS you have written is also a scalar and uses the Einstein summation convention
jola is offline   Reply With Quote
Old   July 4, 2010, 14:29
bearcat
The difficulty is that the index does not repeat in any individual term, we don't have any summation.
http://topex.ucsd.edu/geodynamics/shearer.pdf
this is about solid mechanics, but those concepts such as strain tensor and rotation tensor also apply to fluid mechanics.
Old   July 4, 2010, 17:03
Guillaume Fournier
Guillaume_Fournier is on a distinguished road
Actually, (dui/dxj + duj/dxi)*dui/dxj = (dui/dxj)² + duj/dxi*dui/dxj
Now, you have two terms in which the indexes repeat themselves. Therefore, there is a summation on both i and j for each terms
After a few step, you will get the RHS from the LHS in your first post
Guillaume_Fournier is offline   Reply With Quote
Old   July 4, 2010, 18:27
bearcat
yes, Guillaume, you're right from your direction.
On the other hand, isn't that
S_{ij}=\begin{bmatrix}
S_{11} &S_{12}  &S_{13} \\
S_{21} &S_{22}  &S_{23} \\
S_{31} &S_{32}  &S_{33}
\end{bmatrix}=\frac{\partial U_{i} }{\partial x_{j}}+\frac{\partial U_{j}}{\partial x_{i}} =
\begin{bmatrix}
2\frac{\partial u}{\partial x} &\frac{\partial u}{\partial y}+\frac{\partial v}{\partial x}  &\frac{\partial u}{\partial z}+\frac{\partial w}{\partial x} \\
\frac{\partial v}{\partial x}+\frac{\partial u}{\partial y} &2\frac{\partial v}{\partial y}  &\frac{\partial v}{\partial z}+\frac{\partial w}{\partial y} \\
... &...  &2\frac{\partial w}{\partial z}
\end{bmatrix} (not fully written because of Latex limit here)
and
\frac{\partial U_{i}}{\partial x_{j}}=\begin{bmatrix}
\frac{\partial u}{\partial x} &\frac{\partial u}{\partial y}  &\frac{\partial u}{\partial z} \\
\frac{\partial v}{\partial x} &\frac{\partial v}{\partial y}  &\frac{\partial v}{\partial z} \\
\frac{\partial w}{\partial x} &\frac{\partial w}{\partial y}  &\frac{\partial w}{\partial z} \\
\end{bmatrix}
They are all 3x3 matrices, how can their product be a scalar? Anything wrong with the above expressions?
Old   July 5, 2010, 03:45
Guillaume Fournier
I think you're right in the way you wrote the expressions of S_{ij} and \frac{\partial u_i}{\partial x_j}
However, you're mistaken in the fact that S_{ij}\frac{\partial u_i}{\partial x_j} is not only a product of matrices when using Einstein's convention: you have to sum over i and j, which corresponds to computing the trace of the matrix.
Let me show you. I won't develop the Stress tensor, and I will call each of its components S11, S12....
Let's start with the Einstein's summation convention
S_{ij}\frac{\partial u_i}{\partial x_j} = S_{11}\frac{\partial u_1}{\partial x_1} + S_{12}\frac{\partial u_1}{\partial x_2} + S_{13}\frac{\partial u_1}{\partial x_3} + S_{21}\frac{\partial u_2}{\partial x_1}+ S_{22}\frac{\partial u_2}{\partial x_2} +  S_{23}\frac{\partial u_2}{\partial x_3} + S_{31}\frac{\partial u_3}{\partial x_1} + S_{32}\frac{\partial u_3}{\partial x_2} +  S_{33}\frac{\partial u_3}{\partial x_3}
That will eventually lead to the RHS term you wrote in your first message
Without the convention, it would be a classical matrix product between two 3x3 matrices, yielding a 3x3 matrix as well. If we call it M, we have
M_{11} =S_{11}\frac{\partial u_1}{\partial x_1}+ S_{12}\frac{\partial u_2}{\partial x_1} + S_{13}\frac{\partial u_3}{\partial x_1}
M_{12} =S_{11}\frac{\partial u_1}{\partial x_2}+  S_{12}\frac{\partial u_2}{\partial x_2} + S_{13}\frac{\partial  u_3}{\partial x_2}
M_{13} =S_{11}\frac{\partial u_1}{\partial x_3}+   S_{12}\frac{\partial u_2}{\partial x_3} + S_{13}\frac{\partial   u_3}{\partial x_3}
and so on for the next lines.
We can notice that the RHS term only contains the sum of the diagonal terms of M. Therefore, if you prefer to use the matrix product rather than the Einstein convention to compute and develop your term, you just have to remember that this convention is equivalent to the computation of the trace of the resultant matrix
Here we are. I hope it will help a little
Cheers
Guillaume
Old   July 5, 2010, 13:34
bearcat
Thank you for your explanation. This is very helpful discussion.
Cheers
Guillaume
Simple 1D Stress FE Model Jonny6001 Main CFD Forum 1 March 25, 2010 05:22
1D thermal stress problem simple barrodbeam newsboost OpenFOAM Running, Solving & CFD 3 January 2, 2009 15:12
Questions about the Reynolds stress model empirer2002 Main CFD Forum 1 January 5, 2006 07:37
shear stress scalar definitions? Novak Elliott CFX 0 April 6, 2003 01:45
What is the detail definition of wall shear stress zjm FLUENT 0 January 2, 2002 07:43
