July 12, 2010, 05:56 |
2D Heat Conduction - MATLAB help
Abe
Rep Power: 16 |
Hi all, I am working on the problem below, and I wrote the code, but it's not working. Can anyone help me out? And even any ideas on how to improve the code to make it more succinct?
http://i25.tinypic.com/2v0zi8m.jpg Basically, it is a 2D conduction problem with convection heat transfer on the top, insulated at the bottom edge, and temperature held constant at the left and right edge. The dimensions of the plate are 0.8x0.7 with dx=dy=dx=0.1. I used the symmetry, and the just worked on the left side of the symmetry line (nodes 1-40), wrote nodal equations (finite difference eqs) for each node, and then created a 40x40 matrix in matlab to solve system of unknown temperatures. However, my answer is not even remotely close. It doesn't matter what values I choose for k, h, Tb, q_dot, or any other constants. Here's my code. It's very long. I hope there's an easier way to implement this. IF there is, can someone help me or give me any ideas? clc clear %Material Properties & Constants k = 205; h = 10; qdot = 1000; Tinf = 293.15; Tb = 423.15; dx = 0.1; c = (-qdot*dx^2)/k; d = 2*((h*dx)/k)*Tinf; %Matrices n = 5*8; a = zeros(n,n); b = zeros(n); %node(1) a(1,1)=-2*((h*dx)/k+1); a(1,2)=1; a(1,6)=1; b(1)=c-d; %node(2) a(2,2)=-2*((h*dx)/k+2); a(2,1)=1; a(2,3)=1; a(2,7)=2; b(2)=c-d; %node(3) a(3,3)=-2*((h*dx)/k+2); a(3,2)=1; a(3,4)=1; a(3,8)=2; b(3)=c-d; %node(4) a(4,4)=-2*((h*dx)/k+2); a(4,3)=1; a(4,5)=1; a(4,9)=2; b(4)=c-d; %node(5) a(5,5)=-2*((h*dx)/k+2); a(5,4)=2; a(5,10)=2; b(5)=c-d; %node(6) a(6,6)=Tb; b(6)=0; %node(7) a(7,7)=-4; a(7,2)=1; a(7,6)=1; a(7,8)=1; a(7,12)=1; b(7)=c; %node(8) a(8,8)=-4; a(8,3)=1; a(8,7)=1; a(8,9)=1; a(8,13)=1; b(8)=c; %node(9) a(9,9)=-4; a(9,4)=1; a(9,8)=1; a(9,10)=1; a(9,14)=1; b(9)=c; %node(10) a(10,10)=-4; a(10,5)=1; a(10,9)=2; a(10,15)=1; b(10)=c; %node(11) a(11,11)=Tb; b(11)=0; %node(12) a(12,12)=-4; a(12,7)=1; a(12,11)=1; a(12,13)=1; a(12,17)=1; b(12)=c; %node(13) a(13,13)=-4; a(13,8)=1; a(13,12)=1; a(13,14)=1; a(13,18)=1; b(13)=c; %node(14) a(14,14)=-4; a(14,8)=1; a(14,13)=1; a(14,15)=1; a(14,19)=1; b(14)=c; %node(15) a(15,15)=-4; a(15,10)=1; a(15,14)=2; a(15,20)=1; b(15)=c; %node(16) a(16,16)=Tb; b(16)=0; %node(17) a(17,17)=-4; a(17,12)=1; a(17,16)=1; a(17,18)=1; a(17,22)=1; b(17)=c; %node(18) a(18,18)=-4; a(18,13)=1; a(18,17)=1; a(18,19)=1; a(18,23)=1; b(18)=c; %node(19) a(19,19)=-4; a(19,14)=1; a(19,18)=1; a(19,20)=1; a(19,24)=1; b(19)=c; %node(20) a(20,20)=-4; a(20,15)=1; a(20,19)=2; a(20,25)=1; b(20)=c; %node(21) a(21,21)=Tb; b(21)=0; %node(22) a(22,22)=-4; a(22,17)=1; a(22,21)=1; a(22,23)=1; a(22,27)=1; b(22)=c; %node(23) a(23,23)=-4; a(23,18)=1; a(23,22)=1; a(23,24)=1; a(23,28)=1; b(23)=c; %node(24) a(24,24)=-4; a(24,19)=1; a(24,23)=1; a(24,25)=1; a(24,29)=1; b(24)=c; %node(25) a(25,25)=-4; a(25,20)=1; a(25,24)=2; a(25,30)=1; b(25)=c; %node(26) a(26,26)=Tb; b(26)=0; %node(27) a(27,27)=-4; a(27,22)=1; a(27,26)=1; a(27,28)=1; a(27,32)=1; b(27)=c; %node(28) a(28,28)=-4; a(28,23)=1; a(28,27)=1; a(28,29)=1; a(28,33)=1; b(28)=c; %node(29) a(29,29)=-4; a(29,24)=1; a(29,28)=1; a(29,30)=1; a(29,34)=1; b(29)=c; %node(30) a(30,30)=-4; a(30,25)=1; a(30,29)=2; a(30,35)=1; b(30)=c; %node(31) a(31,31)=Tb; b(31)=0; %node(32) a(32,32)=-4; a(32,27)=1; a(32,31)=1; a(32,33)=1; a(32,37)=1; b(32)=c; %node(33) a(33,33)=-4; a(33,28)=1; a(33,32)=1; a(33,34)=1; a(33,38)=1; b(33)=c; %node(34) a(34,34)=-4; a(34,29)=1; a(34,33)=1; a(34,35)=1; a(34,39)=1; b(34)=c; %node(35) a(35,35)=-4; a(35,30)=1; a(35,34)=2; a(35,40)=1; b(35)=c; %node(36) a(36,36)=Tb; b(36)=0; %node(37) a(37,37)=-4; a(37,32)=2; a(37,36)=1; a(37,38)=1; b(37)=c; %node(38) a(38,38)=-4; a(38,33)=2; a(38,37)=1; a(38,39)=1; b(38)=c; %node(39) a(39,39)=-4; a(39,34)=2; a(39,38)=1; a(39,40)=1; b(39)=c; %node(40) a(40,40)=-4; a(40,35)=2; a(40,39)=2; b(40)=c; T=a\b; fprintf(' Forcing Function Vector \n ') b(:,1) fprintf(' NODE TEMPERATURE (K) \n ') TSolution=T(:,1); contourf(T) for i=1:length(TSolution) fprintf(' %4.0f \t \t %6.1f \n',i,TSolution(i)) end |
conduction, convection, diffusion, heat transfer, matlab |
Heat transfer, convection, radiation, conduction | Sandra H. | OpenFOAM | 1 | March 3, 2010 08:02 |
how to simulate 2d solid heat conduction using CFX | richard | CFX | 3 | March 24, 2008 07:27 |
Conduction heat not balanced? | Nepal | CFX | 7 | May 31, 2005 11:51 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Heat conduction through solid rib in periodic duct | Dieter Fauconnier | FLUENT | 0 | October 7, 2004 08:22 |
