Using the MinGW Compiler with MPI
Like Tree2Likes
  • 1 Post By Rich
  • 1 Post By valgrinda
Old   May 11, 2010, 18:06
Default Using the MinGW Compiler with MPI
Rich
Rich is on a distinguished road
Hello All:
Has anyone used the Open-MPI system in combination with the MinGW compiler suite? I've got MinGW (a gcc-compatible compiler collection for Windows) on my machine and I need to find an MPI release that can be used with it. Anyone have experience here?
Regards,
Rich
aliqasemi likes this.
Rich is offline   Reply With Quote
Old   May 15, 2010, 17:20
Default code::blocks + mingw + MPICH2
Hans Bihs
valgrinda is on a distinguished road
Hei,
I use code::blocks as an IDE for mingw on windows xp 32 bit. For MPI I use the MPICH2 implementation, that works very well in a windows environment, I am not sure about Open MPI (I use it on a mac, though). For the code::blocks/MPICH2 combination, just add the linker and include paths to the compiler settings and you are all set (if you use the default install folders for MPICH2):
linker: C:\Program Files\MPICH2\lib\mpi.lib
Search Directories: C:\Program Files\MPICH2\include
cheers
Hans
kralKA likes this.
valgrinda is offline   Reply With Quote
Old   May 17, 2010, 17:25
Rich
Originally Posted by valgrinda View Post
Hei,
cheers
Hans
Hello Hans:
Thanks for your response. Where did you get your MPICH2 implementation? Did it come with code::blocks, or did you find it elsewhere?
Regards,
Rich
Old   May 17, 2010, 17:28
Default Mpich2
Hans Bihs
Hei Rich,
you can download it here: http://www.mcs.anl.gov/research/proj...hp?s=downloads
Cheers
Hans
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Building OpenFOAM on IRIX lakeat OpenFOAM Installation 7 July 16, 2008 07:27
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 10:54
Is Testsuite on the way or not lakeat OpenFOAM Installation 6 April 28, 2008 11:12
MPI and parallel computation Wang Main CFD Forum 7 April 15, 2004 11:25
