October 4, 2019, 15:19 |
Error in time discretization
federico
Rep Power: 6 |
Hi there,
I'm running a unsteady simulation with a fix delta t of 0.005 . I divided my domain in 10 parts running in parallel, usually after a few seconds of simulation (1.5 s , clock time about 2 hours ) monitoring the log file I see this stuck. So typing CTRL + C to stop simulation and typing ./Processing 10 the program says : " cannot divide in 10 domains as it already is and the says foam exiting. But the simulation start as ever but the time step became with 20 decimals as 1.5462000000000046. At the end of simulation i'm not able to open the result using Paraview. Anyone found this type of error ? |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
