liquid temperature at tube outlet?
Old   October 11, 2010, 20:33
Default liquid temperature at tube outlet?
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
I would like to calculate the liquid temperature at the tube outlet given the following conditions:
1. Tube is made of Teflon (ID 0.06" OD 0.1")
2. Water flows inside the tube at 1.2 ml/sec
3. Assuming constant temperature (306 K) at the outside wall of the tube
4. Inlet liquid temperature is 293 K.
5. Tube length is 0.1 meter
Is there a quick way to estimate the water temperature at the exit of the tube?
I used elmer (www.csc.fi/elmer) to perform the calculation. The results showed that, after 1 cm from the inlet, the water temperature already reached almost 306 K. I am not sure if this is correct giving the high inlet velocity (0.66 m/sec). I am looking for a way to check if this is even close.
Thanks!
Pei
phsieh2005 is offline   Reply With Quote
Phase change from liquid to vapor in a nozzle SebastianSchuster CFX 6 September 28, 2015 22:02
DieselFoam Droplet Temperature Issues - OF 1.6 viv05 OpenFOAM 0 February 27, 2010 11:20
Surface temperature on tube surface Anuj Phoenics 1 November 28, 2006 19:24
Question on checking incell temperature at outlet Guoqing Phoenics 1 June 4, 2003 17:50
emptying liquid from spinning circular tube uvce Main CFD Forum 0 July 2, 1999 10:26
