Laminar Heat Transfer Coefficient
Old   September 23, 2004, 15:31
Default Laminar Heat Transfer Coefficient
Shawn
I am trying to calculate HTC's in a laminar flow regime using correlation for flow over a flat plate.
Nu = 0.664 * Re**1/2 * Pr 1/3
The Nusselt number, Nu = h * L / k Reynolds Number Re = rho * U * L/ mu Prandtl number Pr = mu * Cp/ k
h - heat transfer coefficient
My question is : In these correlations L is the length of the plate, so when calculating HTC's on a cell by cell basis, should I use the cell dimension as the characteristic length ? That does not seem appropriate to me. Any suggestions / comments/ alternative methods for calculating HTC's in a laminar flow ?
Old   September 23, 2004, 16:39
Default Re: Laminar Heat Transfer Coefficient
Jim_Park
Your formula gives the AVERAGE Nusselt number over the entire length of the plate, from 0 to L, where L is from the leading edge.
The formula for the LOCAL Nusselt number, at x, also measured from the leading edge, is
Nu_local = h * x / k = 0.332 * PR^(1/3) * Re^(1/2),
where Re = rho * U * x / mu .
I've taken these from Alan Chapman's "Heat Transfer," now long out of print. But the example is a pretty fundamental boundary layer analysis, so you should find it in most senior or 5th-level heat transfer texts.
So on a cell-by-cell basis, use the local formula that I've typed in above and the local distance (x) from the leading edge to the cell for which you're evaluating h.
Old   September 23, 2004, 22:30
centaur_ks
check out "Fundamentals of Heat and Mass Transfer" - Incropera & Dewitt. It lists all kinds of correlation for flow over a flat plate. Also, a point to note is, check your Reynolds number and Prandtl no because the relation you will use depends on what are the values of this two numbers. hope this helps !!!
heat transfer coefficient as initial value tH3f0rC3 OpenFOAM 9 June 20, 2018 02:45
BOILING HEAT TRANSFER COEFFICIENT John CFX 3 April 4, 2012 17:50
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
Heat Transfer Coefficient los OpenFOAM Running, Solving & CFD 5 January 31, 2010 17:44
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 08:48
