CFD-VIEW tickler.HELP
Old   January 17, 2005, 06:14
Default CFD-VIEW tickler.HELP
w0er
1, How could I plot the vorticity magnitude in CFD-View? 2,How could I creat a new variable,and then plot it? 3,How could I transfer the struct CFDRC results into tecplot or fieldview format.CFD-Tookit?
Old   January 18, 2005, 01:12
Default Re: CFD-VIEW tickler.HELP
Charles
RTFM ... There is a formula editor near the bottom of the screen that you can use to create a new variable, which will get added to the list of plotable variables. You can select the parts (i.e. a given volume, plane or line) where you want this variable, so that it is not necessary to recalculate it for the whole domain. I don't have ready access to VIEW any more, or I would send you a screen dump of it. CFD-Toolkit will translate to other formats, although I think there is little sense in doing it, as a post-processor it is one of the better ones around. It could do with vorticity magnitude as a standard pre-calculated variable though, as well as a wall force integration.
Old   January 18, 2005, 07:05
w0er
Thank you very much for your help.
Old   January 21, 2005, 21:53
w0er
Hey,Charles,I have tried.But i didn't know the function of the vorticity magnitude.How to do ?
Old   January 24, 2005, 01:05
Charles
I see from your other posting that you have now got the function for the vorticity magnitude, so basically you just need to program it into View's expression editor. I can't help you further from here, because I don't have access to View at the moment. Is there any reason why you don't just ask CFDRC's help desk?
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
is there any money in CFD? T Main CFD Forum 35 May 9, 2001 19:35
ASME CFD Symposium, Atlanta, 22-26 July 2001 Chris R. Kleijn Main CFD Forum 0 August 1, 2000 10:07
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 15:01
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
