Publishing New Work
Old   January 14, 2005, 18:34
Default Publishing New Work
noName
I'm looking to publish some computational simulation work: it is application oriented, based on real world engineering, and uses a commercial code. Could anyone recommend a suitable journal? I could eliminate several (JFM, Phys. of Fluids, JCP). How is the ASME's Journal of Fluid's engineering?
Old   January 15, 2005, 06:07
Default Re: Publishing New Work
Eliminated
Why have you eliminated some of the journals?
Old   January 15, 2005, 11:44
noName
I just think that JFM, JCP and Physics of Fluids are less likely to accept publications on work that uses commercial code. Is this reasonable to assume? Or am I wrong?
Old   January 16, 2005, 15:03
Jörn Beilke
http://science.creativecommons.org/
Old   January 18, 2005, 20:45
Adrin Gharakhani
Depends on the focus of the paper. JCP usually accepts papers on methodology development, but you can verify that JFM and Phys. Fluids focus mostly on the physics of the flow (though I've seen papers with methodology flavor in JFM, but more analytical than numerical).
If you plan on running a code and showing some color plots without discussing a serious physical phenomenon (that is still not understood well), then your conclusion is absolutely correct - it will be rejected. For such work it is better to present at a conference, although ASME-JFE may accept the paper version.
Adrin Gharakhani
Old   January 19, 2005, 00:52
Anton Lyaskin
And most code vendors have their own journals, usually they are happy to publish such user articles "showing color plots"
Old   January 19, 2005, 04:58
andy
I think you are correct not to submit to the journals you name which are orientated towards fundamental research. Journals in the field of your application are likely to be more receptive. If you can describe your paper in about a paragraph I would suggest ringing/emailing the editor and asking his/her opinion. They may say no but are likely to offer suggestions.
Old   February 10, 2005, 08:52
kany
I suggest "Progress in Computational Fluid Dynamics" (PCFD) Website: http://www.inderscience.com/browse/i...p?journalID=23
How to work with constant pressure? Martin Siemens 2 February 25, 2009 13:23
Getting FoamX to work shaun OpenFOAM Installation 12 March 23, 2007 08:55
work related to brake study of a vehical aero Siemens 3 November 23, 2006 07:43
Why do the Plant library cases don't work? Alumna Phoenics 6 June 22, 2004 12:08
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 21:03
