!! Slug flow (need references)
Old   January 31, 2005, 04:23
Default !! Slug flow (need references)
Alexander Starostin
I desperately need references on slug flow or gas piston flow. Ones with analitical solutions will be very appreciable.
Thank you beforehand!
Old   February 14, 2005, 08:37
Default Re: !! Slug flow (need references)
ganesh
tell me details with figure
Old   February 14, 2005, 09:42
Alexander Starostin
I mean that there is a vetical tube filled with liquid and a big bubbles floats up. At present I've found analitycal solutions for very long bubble with no end. Maybe someone tried to look at the form of a confined bubble... I would like to see it.
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
Modeling Slug flow Demetrios FLUENT 0 November 23, 2006 16:49
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
References for Two Phase Flow Halim Choi Main CFD Forum 1 December 5, 2001 06:23
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
