Simulation of air flow inside valve - FSI? Help!
Old   April 17, 2011, 16:30
Default Simulation of air flow inside valve - FSI? Help!
farianka is on a distinguished road
Hi
I have been assigned a job to simulate the air flow inside the valve of cylindrical shape. The piston moving inside the valve has a lid and by moving up and down it closes and opens the valve, hence regulates the flow of air through the valve. The piston is attached to valve via spring.
Now, I have no idea how to approach this problem, since I have no experience with this type of set up, I simulated the flow around the car in Ansys CFX previously, but this is different. I need to find out what load should be on the spring to achieve the optimum position of the piston inside the valve, hence optimum flow volume. I am aware that there is something called FSI in Ansys, that deals with valves, but not sure, if this particular case can be resolved via FSI and how complex it is. I have been offered this job, which I have to resolve within 12 weeks, but not sure if this is more complex than I thought. Can anyone advise on what is the best approach to model this?
Thanks a lot.
farianka is offline   Reply With Quote
about valve closing problem during ANSYS FSI simulation ivy CFX 4 June 8, 2011 21:01
Boundary Conditions for Simulation ofcontrol valve Ashraf Sharara FLUENT 1 August 20, 2008 07:54
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
oscillating valve flow Matthias Finke Main CFD Forum 2 September 10, 2003 13:59
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
