Mixing = density change
Old   March 1, 2005, 07:48
Default Mixing = density change
Paul
Mixing = density change.
Say I have two substances A and B of different densities.
If I mix them (50% each by volume) I can calculate the total mixture density by considering a 1m^3 sample and calculate the mass of each present.
Equally, if I mix them (50% each by mass) I can calculate the mixture density by considering a 1kg sample and calculate volumes of each needed.
My question is what if A is at a temperature of 300K and B at a temperature of 1000K. How do I calculate the final density of the mixture in this case? And what about the final temperature?
What equations must I use and how do I use them?
Thankyou for any help.
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 14:20
Variable Density Function ryzd FLUENT 1 August 25, 2011 14:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 17:08
Model foaming process: change the volume / density pmp77 CFX 0 November 18, 2008 09:53
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
