Axial fan simulation in UG/NX 7.5
Old   April 22, 2011, 07:59
Default Axial fan simulation in UG/NX 7.5
fan123 is on a distinguished road
Hi everyone,
For my thesis i have to investigate how well a specific CFD simulation matches reality. The simulation is done with UG/NX 7.5. The problem is the cfd simulation underpredicts the reality quite a lot! I have tried everything to improve the simulation but the simulation never comes close to the reality. So i decided to ask my question here, i hope someone can help me.
So its a simulation of an axial fan (metal sheet blades, 1mm thickness).
The K-epsilon model is used (recommended and it gives the best results).
The fan has a max diameter of 1,2m. The mesh around the fan is unstructured. The mesh size near the blade is 4-6mm, y+ is between 11-200.
To simulate the rotation a rotating frame of reference is used, rotational speed 700 /min.
I hope somene can help me.
Many thanks in advance!
fan123 is offline   Reply With Quote
Old   April 22, 2011, 08:34
i forgot to say the fan is simulated in a square wind tunnel, 10,5 m long, wich is located in a room, no opening / inlet / outlet BC's are used
Old   April 23, 2011, 08:22
How good can CFD normally predict a fan curve?
axial fan nx
Axial Fan Model mardit STAR-CCM+ 0 August 28, 2010 17:16
FloEFD Heat Sink Simulation feature, but with no fan? j.gerber FloEFD, FloWorks & FloTHERM 0 September 7, 2009 08:37
Thermal Cycling Simulation - FAN issue :( Jean-Baptiste FLUENT 1 April 18, 2007 07:41
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
Question concerning about the flow simulation of a fan in an engine room. ghlee Main CFD Forum 3 October 21, 1998 07:05
