Kiva3v2 under RH Linux 9.0, segment error???
Old   March 9, 2005, 07:02
Default Kiva3v2 under RH Linux 9.0, segment error???
LiQiang
I am doing simulation using Kiva3v2 under RH Linux 9.0, when nv (in comkiva.i, number of vertices in simualtion) is defined a bit large, such as 1000000, the message printed in the screen is " segment error", What can I do ??? Help needed!
Thanks in advance
Old   March 10, 2005, 02:50
Default Re: Kiva3v2 under RH Linux 9.0, segment error???
Z
I think it is not able to allocate that much memory. Free some memeory and rerun it again. Z
Old   March 10, 2005, 20:52
LiQiang
Can any one give me some advice on improving the accuracy of KIVA3v2
Old   March 11, 2005, 05:25
Z
If you need some help give us full information
Old   March 11, 2005, 21:45
LiQiang
dear Z.
I am doing some simulation for Ch4+air combustion using kiva, and in our computation domain, there is a shockwave in the downstream, formed by the hot gases and a compression, and we know that in Kiva3v, ALE + quasi-second order difference scheme is used, and it has a very low resolution for shockwaves, so we think some modifications should be done to it, perhaps other difference scheme is better, and from an ETD dissertation, I know some one has combined the central difference and quasi-2nd difference scheme to get a higher order scheme, but I can not get this dissertation, another aspect, I am not familiar with all the subroutines ji Kiva, so at present, the only way is to ask for help on Intrernet, Can you help me on this area, and do you have explanations to the subroutines in Kiva, Help needed very much!!! Plaese mail to me , and I am glad to be in touch with you by email directly. Thanks in advance
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
