Axial Flow Fan
Old   December 19, 2010, 23:35
Default Axial Flow Fan
SCORPION
mawais15 is on a distinguished road
I wonder if there is a mathematical formula to calculate the flow rate of a fan if following parameter are known
  • Fan effective diameters
  • Blade Angle ( Pitch )
  • Number of Blades
  • Speed ( RPM )
  • Power Consumption
  • Pressure at inlet of the fan
Regards
mawais15 is offline   Reply With Quote
Old   December 20, 2010, 01:31
Hamid Zoka
Hamidzoka is on a distinguished road
there are some empirical ralations for such this calculations.
but they are limited to some specific geometries and their application is limited.
regards
Hamidzoka is offline   Reply With Quote
Old   December 20, 2010, 01:38
SCORPION
i have measured the basic dimension and geometrical equation of the fan that i am going got measure the flow rate of.
but i don't know the relations. :-(
Old   December 20, 2010, 01:39
SCORPION
why are you saying that its application is limited?
Old   December 20, 2010, 02:01
Hamid Zoka
there are some coefficients for these relations which are function of blade geometry as well as type of the flow. they are usually available just for some limited fan blade shapes and flow types.
regards
Old   December 20, 2010, 06:07
SCORPION
Oh i c...!!
Old   May 26, 2011, 04:05
Default uss
Urmil Shah
urmilshah is on a distinguished road
hey,
I am working on the design of a low pressure axial flow fan.
I have generated the aerofoil sections at 5 different radii of the fan
along with their stagger angles. What I am struggling with is how they are
to be oriented with respect to each other in the axial direction. For a
aerofoil at a given radii, I have found its its stagger angle. But, I
could still translate it along the circumference (i.e. sweep) and along
the axis of the fan.
I am unable to decide how to move the sections along the axial direction,
before I pass a best fit surface through them to generate a fan blade.
Also does anyone have any idea on how to decide on sweep angle ?
urmilshah is offline   Reply With Quote
Old   May 26, 2011, 08:42
SCORPION
Originally Posted by urmilshah View Post
hey,
what softwares u r using??
any image will be helpful
Flow recirculation around a ducted fan Jane Main CFD Forum 2 January 24, 2012 05:17
Axial flow turbine approperiate B.C dia aisa CFX 0 April 30, 2008 03:32
How to model flow of centrifugal fan? Peter Main CFD Forum 0 April 2, 2008 06:07
Axial Fan Russ FLUENT 8 July 7, 2006 13:59
Question about flow in ducted fan in another duct Jane FLUENT 0 June 21, 2004 13:57
