Y-Plus values at aerofoil leading edge and trailing edge at high incidence
Like Tree2Likes
  • 1 Post By Far
  • 1 Post By Martin Hegedus
Old   July 27, 2011, 13:36
Default Y-Plus values at aerofoil leading edge and trailing edge at high incidence
Engr07 is on a distinguished road
Hi all,
I simulated flow over an aerofoil to get the forces and moment using Spalart-Allmaras turbulence model. The grid was done so as to achieve the y-plus values less than 1.0.
At zero degree I was able to keep the y plus less than 1.0 over the complete aerofoil but not the trailing edge-The aerofoil has a blunt trailing edge.
At 10 degree y-plus values at the leading edge were about 3.0 and were also larger than 1.0 at the trailing edge.
Since it is "good practice" to keep the number less than 1.0, I need to know how significant is the issue of not achieving this at the leading and the trailing edges.
Any help is greatly appreciated.
AMal
Engr07 is offline   Reply With Quote
Old   June 28, 2012, 18:49
Lee
rlc113 is on a distinguished road
Hey AMal, it has been my experience that the y+ values are crucial to drag prediction. I am currently working on a similar case in which my y+ values are << 1 everywhere except the Leading edge. When comparing my case with a case ran with someone with a bit more experience I noticed a significant underprediction on my solution. I have added more fidelity and decreased the delta1 value in that area and I am rerunning the case. I will report back with the difference.
Let me know if you find anything yourself.
rlc113 is offline   Reply With Quote
Old   June 29, 2012, 03:41
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
with the hybrid wall functions (currently implemented in major CFD codes), the yplus values needed are Y+<10. See this reference :
http://num.math.uni-goettingen.de/ba...ings/knopp.pdf
http://num.math.uni-goettingen.de/ba...ngs/alrutz.pdf
http://tau.dlr.de/fileadmin/document...8_englisch.pdf
http://proceedings.fyper.com/eccomas...cuments/64.pdf
atg likes this.
Far is offline   Reply With Quote
Old   June 29, 2012, 04:22
Lee
Hey Far, thanks for the info, I haven't checked it all out yet. Just wanted to say that the only solver I use is NASA's FUN3D, which to my opinion doesn't have a wall function. Any insight to that would be interesting.
I have the refined BL case running now. I also have the results of a case in which the inviscid spacing was refined by 40% or so, I will post up all my results when the the results are apparent.
Old   June 29, 2012, 10:42
Martin Hegedus
Martin Hegedus is on a distinguished road
For the SA model I usually try to get the y+<1 at about 5% to 10% of the chord. I doubt it matters for less than 5%, if the majority of the airfoil y+ is less than 1. The eddy viscosity at the leading edge is usually very small. It builds up along the chord. Thus, the leading edge flow is laminar, even when using the turbulence model. However, that is dependent on angle of attack. So, look at your eddy viscosity. As for the trailing edge, usually the boundary layer is thick, so I'm not sure why you are having an issue there. Unless you have a recirculation bubble at 10 deg. But, if you are at the very trailing edge tip, I doubt it matters. Again if the majority of the airfoil is y+<1.
If you are concerned, the best thing to do is reduce the off wall grid spacing by 1/2, run the code, and see if you get a difference in the skin friction.
atg likes this.
Martin Hegedus is offline   Reply With Quote
[ICEM] Hole near sharp trailing edge of airplane/wing geometry jlichtwa ANSYS Meshing & Geometry 2 September 21, 2010 15:19
Which trailing edge is correct for meshing of aerofoils for CFX LSC CFX 0 May 10, 2009 12:45
Meshing trailing edge of aerofoil CC Main CFD Forum 7 December 10, 2008 20:22
Meshing trailing edge of aerofoil CC FLUENT 1 December 10, 2008 03:49
trailing edge problem Kuo Wei-Jen Main CFD Forum 2 April 14, 1999 10:09
