how to deal with the boundary conditions in SPH ?
Old   June 16, 1999, 07:20
Default how to deal with the boundary conditions in SPH ?
liu xiao
Hi, everyone,
How to deal with boundary conditions in the Smoothed particle hydrodynamics ?
Thank you
Old   June 16, 1999, 10:13
Default Re: how to deal with the boundary conditions in SPH ?
Patrick Godon
Hi THere,
For open boundaries there is no problem, you can just assume that once a 'particle' is far from you computational domain then it has to be removed. In regions where the number of particles becomes fairly small, the flow is not represented accurately and the results are much less accurate (regions of low density), that's another problem you have to take into account.
For rigid boundaries it is more tricky and I have heard of several ways of implementing the rigid boundary conditions. The simplest thing is just to 'fix' particles at the location of the boundary and not allowing them to move Another method is to put a potential barrier that the particles would not be able to 'cross'.
I am sure if you make a litterature search for Joe J. Monaghan, you should find enough papers to answer all you questions. Since your question is quite general it is difficult to go into more details.
I hope this helps. Patrick.
Old   June 17, 1999, 19:58
Tony Chen
Hi, I found one: Monaghan, JJ (1994), "Simulating Free Surface Flows with SPH", J of Computational Physics, V110, pp.399-406.
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 05:35
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 09:38
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
