Problem with pump simulation using Solidwork 2010
Old   November 22, 2011, 10:03
Talking Problem with pump simulation using Solidwork 2010
nurul
nurul_msia is on a distinguished road
i'm currently doing flow simulation of pump using Solidwork 2010. The result after the simulation showed the inlet pressure greater than outlet. In my understanding of pump, pressure inlet must less than outlet. Any one can help me why does this happen??? my boundary condition as below:
inlet BC: volume flow rate (absolute selection)
outlet BC: environment pressure
wall: Real wall for the specific non-rotating wall (stator)
Goal:
surface goal: inlet static pressure
surface goal: outlet bulk static pressure
torque: for the rotating impeller
pressure drop: pressure inlet-pressure outlet
efficiency: pressure drop*volume flow rate/rotational speed/torque
result after simulation:
pressure inlet: 114691 Pa
pressure outlet: 101737 Pa
please help me...
nurul_msia is offline   Reply With Quote
Problem with centrifugal pump calculation Michiel Main CFD Forum 2 June 17, 2012 21:32
Pump Station Simulation GUSU CFX 6 October 14, 2009 06:40
Peripheral pump CFD simulation Nevel Main CFD Forum 0 October 8, 2009 01:09
Sliding vane pump problem usker Siemens 0 April 26, 2007 06:45
Help: axial pump :Iges problem nithyanand FLUENT 5 February 2, 2005 04:25
