timestep for viscous compressible flows
Old   July 11, 2005, 07:20
Default timestep for viscous compressible flows
Ravi
Can anyone suggest a good timestep formula for explicit compressible viscous flow on unstructured grids. On quadrilateral (2D problem), if i stretch cells at wall boundaries solution is diverging after some number of iterations even if i use small cfl number. problem is converging for triangular grids as amount of stretching is less compared to quadrilateral grid.
Old   July 11, 2005, 11:19
Default Re: timestep for viscous compressible flows
Salvador
dt < rho*Pr*L^2/(4*gamma*visc)
where L is a charateristic dimension of the cell
check Turkel et al.(1991), NASA TR.
Old   July 12, 2005, 13:51
lavan
Thank you for your response.
Earlier for inviscid computation i am using fallowing timestep.
dt = sqrt(area of cell)/(sqrt(u^2+v^2)+ c).
u and v are two velocity components, c is wave speed.
the time step which you have suggested is alone sufficient for viscous computation or i need to combine both inviscid, viscous time steps? how can i get the paper which you have suggested.
Thank you.
SIMPLE pressure correction in compressible flows Maarten de Jong Main CFD Forum 7 April 30, 2012 02:23
Using pressure based solver for compressible flows aamer Main CFD Forum 2 June 15, 2011 12:45
Case check - Velocity-Inlet not compatible with compressible flows fluent-user FLUENT 2 September 15, 2009 08:46
coupled solver for compressible flows rean Main CFD Forum 0 September 18, 2008 04:10
PDF Model in compressible flows with shock waves Hanxsi FLUENT 0 February 26, 2006 20:51
